Username Post: replacing 5.3L with reman        (Topic#352930)
patientasafarmer
Reg: 07-28-10
09-10-18 05:54 AM - Post#2745785
About the pull the trigger on a remanufactured long block for my 2007 Silverado... (it's burned 1qt oil per 2k mi and is now tapping extremely loud w check engine light). Looking at Rock Auto or Powertrainproducts.net (other suggestions/feedback welcome!)
Thinking about buying a kit to delete the AFM.
Powertrain Products is $2,999. (i think their engine warranty is 4 years).
Rock Auto has a few options ranging from $1900 (VIN O) to $2,500 (VIN M). Warranty is 3 yr/30k). My truck is VIN M, but - do I need the more expensive long block if I am deleting AFM?
Any help is greatly appreciated.
Thanks,
Rob
Here are all my options at Rock Auto...
https://1drv.ms/u/s!AhJJeOjS9h-kj14Pk1 kp5UGdWmJm
Link
[image]https://zmaleg.ch.files.1drv.com/y4mNh8dBgyxqsEhbXgjOQ JhYwC99Aaknj8W0MF-HtxWo-o WB2ClzqL-HtHWO6Cctyj2gbQH ZK8QwBOiJ-jLafIFcyXFyUaZs AdQkL9kTNySvMARnlJcJXJCzM jyGLMHVTN3q-S3nIenGy5uyjC 6bPlFON-EGcgSmhmO-moOJ6UU -kvWUFRRSF-ch-pTgVAewR4UR c7axRGrFGzcxGeiz59yMw?wid th=1516&height=600&am p;cropmode=none[/image]
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
09-10-18 06:10 AM - Post#2745786
    In response to patientasafarmer
If you don't want to actually do the mechanical changeover to get rid of the AFM, I'd suggest this.
https://rangetechnology.com/afm-disabler/
It is actually a little cheaper on Amazon. $175.
I put one on my 2009 Silverado, and I love it. I have moved it to my wife's Escalade for long trips a couple of times, and it works flawlessly!
My mileage went from 15.3 avg to 15.8.
No, I'm not a salesman. I just want to share some good info.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Edited by beagrizzly on 09-10-18 06:13 AM. Reason for edit: No reason given.
patientasafarmer
Reg: 07-28-10
09-10-18 10:10 AM - Post#2745811
    In response to beagrizzly
Thanks Griff!
65_Impala
Reg: 12-29-02
09-27-18 09:42 AM - Post#2747338
You do have to watch the older engines because the older stuff will have a 24x crank sensor and a 1x cam sensor while your engine will have a 58x crank sensor and a 4x cam sensor. This change happened somewhere around 2005 or 2006 so a 2006 or 2007 GMT800 wrecker pull or rebuilt engine might be the sweet spot between having the right sensors (reluctor rings) and no AFM.
Around here, I could scrounge up a usable 5.3L or 4.8L without AFM for about $500. Any place around there to find such a thing?
If you do use an engine without AFM then you'll have to find a tuner to tune it out of the PCM.
Execution time: 0.069 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:59 AM
