Username Post: radiator drain ?        (Topic#352921)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
09-09-18 08:42 AM - Post#2745715
I have a 2000 Blazer V6 2wd. auto with oil cooler. the plastic tank broke. new one on the way.
I can just barley get my fingers on the drain. I cant see it after I get my hand down below the hose. anyway, I can't get it to turn. is there a secret, a special tool or?
thanks Rod in AZ
09-09-18 11:50 AM - Post#2745728
    In response to rod
Channel locks and from underneath. Have you removed the shroud?
'08 GMC Acadia 3.6L SLE
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
09-10-18 08:04 AM - Post#2745802
    In response to rod
Make your life easy and pull the lower hose. If you're looking to re-use or recycle, put a large shallow pan under it.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Execution time: 0.202 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:27 AM
