Username Post: Truck is overheating        (Topic#352912)
panthersl56
Reg: 04-05-14
09-08-18 11:02 AM - Post#2745655
Truck was giving me problems overheating and reducing power, changed out the thermostat, water pump, fan clutch, coolant sensor and coolant sensor wires. Truck still overheats but I’m sure it’s not. When I start it in the morning it immediately starts to overheat and reduce power. Changed out the belt too. Once I drove for a while it reduces power and computer tells me it’s overheating and not overheating and my gauge goes up and down with no set tempature, any ideas? Going to flush the radiator today
2plus2
Loc: Mission,BC
Reg: 02-03-05
09-08-18 12:15 PM - Post#2745662
    In response to panthersl56
When you start it in the morning and it instantly overheats,what is instant? A few seconds?5min?
69 Canadian Pontiac 2+2
panthersl56
Reg: 04-05-14
09-08-18 01:24 PM - Post#2745665
    In response to 2plus2
Few seconds
2plus2
Loc: Mission,BC
Reg: 02-03-05
09-08-18 03:27 PM - Post#2745675
What motor are we dealing with?
09-08-18 05:37 PM - Post#2745686
It takes a while for the engine to build up heat from cold, so it can’t immediately overheat. I’m not familiar with how the computer reads the temp. to determine overheating. You said you changed the sensor and wiring. What about the sending unit for the gauge? You could also have a steam pocket in the cooling system. This can give false readings to sensors and sending units. Do you have good heat in the truck? I know you haven’t probably been running the heat, but no heat is a good indicator of a steam pocket. Running the truck with the radiator cap (overflow bottle cap) off and revving the engine to about 3,000 RPM can help clear an air pocket. If the truck lets you rev it that high on reduced power.
1957 Cameo Carrier
panthersl56
Reg: 04-05-14
09-08-18 07:22 PM - Post#2745691
6.0l gas
panthersl56
Reg: 04-05-14
09-08-18 07:23 PM - Post#2745692
    In response to wagonman100
I have no steam pocket, and haven’t checked sending unit
panthersl56
Reg: 04-05-14
09-08-18 07:23 PM - Post#2745693
Truck does let me rev it that high but when I drive it gives me a stutter like it’s a misfire and my gauge goes crazy
2plus2
Loc: Mission,BC
Reg: 02-03-05
09-08-18 07:38 PM - Post#2745694
What happens to the guage when you turn the key on but you dont start it?
panthersl56
Reg: 04-05-14
09-08-18 10:27 PM - Post#2745696
Stays like stock but once I start it, it goes up or sometimes stays cool
jktucker92
jktucker92
Reg: 02-05-17
09-12-18 06:36 AM - Post#2745962
Check your grounds thoroughly. Electrical sensors can get an incorrect signal if the engine isn't properly grounded. Often causes other weird problems too. As mentioned above, even under the worst conditions, an engine can't overheat in seconds, so it must be an incorrect reading of some sort. Possibly a issue with the ECM.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-12-18 04:27 PM - Post#2745992
    In response to jktucker92
You never shared what year it is or I missed it. The clusters on 03-6 GM's have a problem with stepper motors going bad. Do you have a scan tool that shows data? See what the ecm shows as far as engine temperature.
Execution time: 0.098 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:57 PM
