Username Post: Rochester 2gc idle mixture adjustment.        (Topic#352907)
killerkjn
Loc: Edgewood, WA, usa
Reg: 12-19-02
09-08-18 05:44 AM - Post#2745633
I haven’t given this any thought before but the manual tells you to set the idle speed with car in drive. Then set the mixture screws. I have always put the car in park or neutral when setting the mixture. But should I keep it in drive? How do you guys do it?
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
09-08-18 09:07 AM - Post#2745647
    In response to killerkjn
You should follow the manual. Leave it in Drive, (or reverse), set the idle speed, then adjust the mixture screws for the highest vacuum reading with the gauge tee'd into the distributor vac advance.
The mixture screws should be the LAST thing you adjust, after everything else has been adjusted and the engine is warm.
Verne
killerkjn
Reg: 12-19-02
09-08-18 09:21 AM - Post#2745650
    In response to Verne_Frantz
Thanks for the quick reply Verne. I will give that a try.
Execution time: 0.111 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:43 PM
