Username Post: powerglide help        (Topic#352886)
5557mad
Reg: 11-17-11
09-06-18 08:05 PM - Post#2745542
55 org. 6cyl powerglide. when cold transmission shifts just like it should. shifts up shifts down perfect. once it gets hot will not shift into second gear.was told to check to see if the drive pin for rear pump was sheared off. it was not. fluid is correct level. going down the road shift to neutral shut car off then back on shift to drive and the car will start and sometimes it wont. what should i check next. thank you
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
09-06-18 09:30 PM - Post#2745552
    In response to 5557mad
Low band adjustment correct? Toss a can of "Trans-Medic", or a similar product, into the trans. It will help to "soften the seals", making them seal better. It's usually only a temporary fix, but it will give you an idea of the overall condition of the trans (personally, I've never had any luck doing that, but every person I've recommended it to has). Trans gets "hot", clearances "open up", and fluid leaks by the seals in your case. And the really bad thing about it all? If it does need to be rebuilt, it will cost you $$$$$. Old equals expensive I guess. I am Butch/56sedandelivery.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
09-09-18 03:32 PM - Post#2745737
If the pin is sheared it will never up-shift.
The pressures should be checked when hot as per shop manual.
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
10-01-18 04:26 AM - Post#2747582
IF YOU NEED A 235 trans i have one with only 40,000 miles out of a 56 i see you live in wash so it might be too much to ship
Edited by STEFAKI on 10-01-18 04:28 AM. Reason for edit: No reason given.
STEFAKI
STEFAKI
Loc: ohio
Reg: 12-26-02
10-01-18 04:31 AM - Post#2747583
i have a 235 trans out of a low mileage 56 4-DR if you need one it is complete even has original oil lines where are you located
Execution time: 0.076 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:05 AM
