Los59
Loc: Phoenix, AZ
Reg: 11-14-10
09-06-18 07:20 AM - Post#2745470
I am trying to determine the color of the bottom of the trunk and interior of the trunk as well on a two tone '59. It appears from the photos below that both the bottom of the decklid, hinges, and trunk were all matching the upper two tone color.
I will be going with a two tone Grecian Gray Poly (lower)/Snowcrest (upper) White.
[image]https://www.dropbox.com/s/f8jtr647aitg9rs/061 1lrmp_10z-1959_chevrolet_ impala-trunk.jpg?dl=0[/image]
[image]https://www.dropbox.com/s/vvyw2scy4c3x19e/128 46_ae621fa6ed_low_res.JPG?dl=0[/image]
[image]https://www.dropbox.com/s/s5jy625b37wn82m/208 785twotone%20trunk.jpg?dl=0[/image]
1959 Impala Sport Coupe Factory 4-Spd |
59cheviac
Loc: the sunshine state
Reg: 10-31-03
09-07-18 01:18 AM - Post#2745554
In response to Los59
Everything painted in the trunk should be the same color as the upper color on the body, or in your case, white.
Jerry Acheson
Loc: Green Oaks, IL
Reg: 12-30-00
09-07-18 05:04 PM - Post#2745613
In response to 59cheviac
This is correct. The trunk is the color of the decklid.
Los59
Loc: Phoenix, AZ
Reg: 11-14-10
09-10-18 05:05 AM - Post#2745782
In response to Jerry Acheson
Thanks guys, at first I was envisioning a darker color for the trunk as I was going to install the mats. Shouldn't look too bad.
