Username Post: coupe quarter windows        (Topic#352856)
dkcoupe
Loc: Edmonton, Alberta, Canada
Reg: 08-16-11
09-04-18 06:41 PM - Post#2745328
My 47 coupe has the sliding opening rear quarter windows. The driver's side lever has broken. Been driving it for 28 years and over a hundred k and have opened that window a lot. So I need to find a replacement. My question is do other body styles use the same type and size of mechanism? I've never looked that closely at aerosedans or 2 door sedans rear windows.
Chevs of the 40s
Broo102
"4th" Silver Supporting Member
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
09-04-18 09:13 PM - Post#2745341
    In response to dkcoupe
You can find one fairly easy for the D/S front. Go the site called Salvage and junkyards for classic cars. It lists them from all over the country. Also ebay motors has them, Ive seen them in the past. I believe The Car Shop in Orange , Ca. has them
Good hunting!
Bru
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Edited by Broo102 on 09-04-18 09:13 PM. Reason for edit: No reason given.
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
09-05-18 03:58 AM - Post#2745354
One of the sliding rear windows was cracked in my 46 sedan. I removed it and took it to a local car glass shop and they just cut me a new one. I dropped it off at 10 am and picked up the new on around 2 pm. As long as it is flat glass and no curves, any shop should be able to make you one.
I left the metal piece (the part that rides in the track, on there and they installed that on the new glass for me.
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
Jack Crain
Reg: 07-24-11
09-05-18 08:31 AM - Post#2745387
    In response to Jack Crain
Ooops! I just re-read the original post. Sorry, I thought you need the glass, not the lever.
HEI ignition
Front Disk Brake
T-5 Tranny
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
09-05-18 12:38 PM - Post#2745413
The four door sedans (sport sedans) had the sliding windows. I don’t know if the entire track was the same but the lever should be the same. The windows on the sedan and coupe look about the same size, so maybe they would interchange.
dkcoupe
Reg: 08-16-11
09-05-18 05:50 PM - Post#2745445
    In response to lofat46
Thanks, I looked at a manual today and it confirmed showed the four doors have rear sliding glass so I might have an easier time finding one being parted out than a coupe. And yes it is the mechanism I need not the glass, but thanks for the replies.
Chevs of the 40s
Execution time: 0.073 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:20 PM
