Username Post: 1996 Impala SS start/stall        (Topic#352688)
centsless
centsless
Loc: Forest Hill MD
Reg: 10-28-13
08-24-18 04:14 PM - Post#2744267
My 96 has been sitting for a while. I charged the battery, and decided to drive it to work today. I work 1 mile from home. Morning commute was fine. This afternoon, as soon as I got out on the road it went about 1/4 mile and suddenly shut off. I had it towed home. At first it would start if you hold the pedal to the floor. once it started and you let off the pedal it would idle, but as soon as you touch the pedal it would shut down. Now it will start with the pedal to the floor, but as soon as you let off the key, it stalls.
Any ideas?
Bob
66 Impala convertible
66 Biscayne 427 2 door post
66 Caprice 4 door hardtop
66 Caprice 2 door
81 Corvette
96 DGGM Impala SS
01 S10
15 Silverado
2003 Crown Victoria LX Sport "Icky Vicky"
1965-66 FSCC member #530
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
08-26-18 05:06 PM - Post#2744476
    In response to centsless
Check fuel pressure and report back. Ck engine light on?
centsless
centsless
Loc: Forest Hill MD
Reg: 10-28-13
03-31-19 04:29 PM - Post#2763343
    In response to junkman104
I checked fuel pressure, spark, timing, etc. No codes and all checks were good. # days later the car started and ran perfect. Occasionally it would stall and most of the time it would not re start unless it sat for a while. Figured it out today. Coolant temp sensor was intermittently dropping to -5 and -10 degrees. Connector was clean and tight, so replaced the sensor and so far so good...
Bob
66 Caprice 2 door
81 Corvette
96 DGGM Impala SS
01 S10
15 Silverado
Execution time: 0.267 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:47 AM
