Username Post: What would cause an INCREASE in RPM while sitting at a light, in gear?        (Topic#352525)
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-16-18 10:35 AM - Post#2743265
Never experienced this one before. I recently upgraded my fuel system (to great results apart from this intermittent issue) to a 255lph EFI fuel pump and Aeromotive bypass regulator (the one designed to work with a carb and EFI pump). Fuel pressure is rock solid at 6.5 psi. Holley Street HP 750VS carb. Feed and return lines are both 3/8" with no restriction based on the rock solid fuel pressure.
Every once in a while when I'm sitting at a light, the RPMs will increase with no input from me. I've seen as much as 1700rpm or so before throwing it in neutral and blipping the throttle, which cures it. It's only done it a couple times, and totally at random. There doesn't seem to be any surging going down the road. The car runs better than it ever has, as I was clearly having fuel delivery issues before with the mechanical setup. Where I used to get a decent second gear scratch on a manual shift, it will now kick the back end sideways. Definitely putting more power down.
Since you need more fuel to increase RPM, my guess is I'm getting a random leak from the carb, like fuel is getting pushed past the boosters. The only thing I have changed is from a mechanical pump to an electric EFI pump, and all related plumbing. I did have to pull and clean both needle and seat assemblies since the initial prime on the EFI pump was over 20 psi. This was after backing the adjustment screw off what I thought would be enough. WRONG. I found some rubber hose fragments lodged in both assemblies, but they looked and operated fine otherwise. Could a little piece of something be causing this issue?
I'd love to hear your thoughts. It's not a major issue, I'd just like to correct it if possible.
Bill -
1955 Chevy D/Gas Tribute "Glory Stomper"
Edited by Mr. Sinister on 08-16-18 10:38 AM. Reason for edit: No reason given.
08-16-18 12:32 PM - Post#2743277
    In response to Mr. Sinister
Generally for the idle speed to increase, more air must be introduced in some fashion. Worn throttle shafts in the carb, some kind of binding in the linkage, any vacuum leak..In one instance, and this very rare, a failing torque converter stator caused erratic idle speeds.
Edited by Shepherd on 08-16-18 01:08 PM. Reason for edit: No reason given.
08-16-18 01:22 PM - Post#2743285
Since blipping the throttle fixes it, I would suspect a carb linkage problem, from bad motor/transmission mounts.
As mentioned, excess fuel won't increase RPM without AIR, it only makes it run rough.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-16-18 03:54 PM - Post#2743295
    In response to acardon
I would check the centrifugal weights and springs in the distributor. If they are not free or the springs too loose the timing will fluctuate causing the rpm's to be unstable
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-17-18 05:32 AM - Post#2743356
    In response to aghaga
Thanks for the input!!
It's a steady increase of RPM from my in-gear idle speed of about 700rpm, up to as high as (I've seen) 1700 RPM. It doesn't jump around, just a smooth increase like I was giving it gas. It will typically start to increase in RPM after I've been sitting at the light for a bit.
The linkage thing is interesting, I did change to a new linkage rod with heim joints on either end. There's no binding that I can tell and I tested and adjusted it thoroughly when I installed it for smooth operation and full throttle. I think this is the best place to start looking.
There no slop or play in the throttle assembly, I had the carb off for a good cleaning when I had to pull the needle and seat assemblies.
I've had vacuum leaks before that will increase the RPM a little, but definitely not 1000 RPM in gear.
Engine mounts are good (solid steel) as is the trans mount. Minimal movement when I stab the throttle, and no banging under the car when I gas it going down the road.
Bill -
Edited by Mr. Sinister on 08-17-18 05:37 AM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-17-18 05:52 AM - Post#2743359
have you considered a rather simple test... adding an additional throttle return spring, as a temp test to see if adding additional resistance, it provides from the carb opening from the at idle set location prevents this from occurring?
carb and in some cases transmission shift linkage that goes to a carb must be free from binding.
if it does you've almost limited the cause to a binding or badly adjusted linkage ,
yes it might be a P.I.T.A. as the additional throttle resistance might be a problem but as a temp test it can provide you with info and facts
Edited by grumpyvette on 08-17-18 06:12 AM. Reason for edit: No reason given.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-17-18 05:55 AM - Post#2743360
    In response to grumpyvette
I haven't, but that's too simple of a test to not try. I have a fairly heavy spring on it now, and I'm pretty sure it was part of a 2 pack I bought however long ago. I'll see if I can find the other one and stick it on there too.
Bill -
IgnitionMan
Reg: 04-15-05
08-17-18 10:35 AM - Post#2743382
Fix the air leak under the carb.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-17-18 11:49 AM - Post#2743397
    In response to IgnitionMan
Wouldn't that be a constant source of high RPM and other vacuum leak related issues? Apart from the very occasional idle speed increase only in gear, it's running damn near perfect, and when it does its new trick, it does it very smoothly. Idle speed otherwise is exactly where I had it set before removing the carb for maintenance. It doesn't jump up, it steadily builds RPM until I blip the throttle, which settles it back down to normal. It's only done this 3 times in a couple hundred miles of driving.
Bill -
IgnitionMan
Reg: 04-15-05
08-17-18 04:04 PM - Post#2743417
Free idle vs pulling against a torque converter load.
Member #409
08-17-18 07:27 PM - Post#2743440
Huh?
IgnitionMan
Reg: 04-15-05
08-18-18 08:23 AM - Post#2743498
Yes, have seen it happen, even does so on EFI engines when the mixture is right on out of gear and engine is at ops temps, and an idling load is applied. Doesn't take much. A very small vacuum leak can have little to no effect at idle out of gear, but cause idle to rise to overcome loading of the engine.
Stop questioning me as if I have no brains, I am not stupid, and have worked in these fields for over 45 years, some of them at GM, and Holley.
08-18-18 09:50 AM - Post#2743508
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-20-18 06:56 AM - Post#2743717
I'll pull the carb and spacer just to be sure, since that's an easy thing to check.
Bill -
IgnitionMan
Reg: 04-15-05
08-20-18 10:01 AM - Post#2743753
IF you have a propane torch, might flow a low volume of UNLIT propane around the carb and adapter bases when it is idling high, and see if it drops down by itself.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
08-27-18 10:12 AM - Post#2744552
Update: Pulled the carb and spacer, found no apparent leaks. Both gaskets looked good.
Added my second spring to the linkage, and it seems to have changed what's happening when it happens. Instead of increasing RPM on its own now, if I tap the gas a little at a light in gear, it will rise a few hundred rpm. Once it hung at about 1300rpm, and once it rose to about 1300rpm, then dropped back down. It idles really strong at about 700-750 in gear with the EFI pump setup, which I'm pretty pleased with, but it does cause the idle to hang at about 1100rpm when free revving sometimes. I'm thinking I need to adjust that throttle linkage rod a little, I think it may be a hair too short.
Bill -
Edited by Mr. Sinister on 08-28-18 07:33 AM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-27-18 10:34 AM - Post#2744555
sure sounds like binding linkage
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
08-27-18 03:41 PM - Post#2744590
could be the air cleaner housing or something along
the accel rod. jmho jim
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
10-01-18 11:07 AM - Post#2747617
    In response to jdk
Well, I seem to have found the issue. Was out putzing around on Saturday and the car was running like an animal all day, with no issues at all. Made a hard 3 gear pull up a hill close to home. Let off the gas at the top of the hill and coasted about an 1/8 mile to the back entrance of my neighborhood. I could tell right away something was off by the way it was coming down the RPMs. Coughing, sputtering, then died at a stop sign. Had to hold it wide open to get it to fire. So, flooding badly. Switched off the fuel pump and it all cleared up. Switched it back on, same problems. Got it home and pulled the air cleaner. Keeping it running with the fuel pump on resulted in fuel pouring out of the secondary throttle rod holes in both sides of the carb, and a steady drip from the secondaries at idle. Primary rod holes are bone dry, and no leaking from the boosters. Turn the pump off, no issues.
Pulled the carb and found there's a ton of slop in the secondary rod bores. This carb is 5 or 6 years old, so not old enough to have this amount of slop in the secondary side. Primary was nice and tight.
What the hell could have caused this?
In any event, looks like I'm rebuilding the carb.......
Bill -
Jims56chevy
Jims56chevy
Loc: chino valley az
Reg: 11-23-04
10-01-18 11:44 AM - Post#2747619
You either have to much pressure from the pump or you have a carb full of crap that is holding your seats open.
56 210 2dr
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
10-01-18 12:19 PM - Post#2747621
    In response to Jims56chevy
Pressure is regulated to 6 psi, and I know I blew a bunch of junk into the carb and floated both needles when I put this new EFI pump on it because the Aeromotive regulator designed to run this setup with a carb was preset at over 15psi (where my gauge maxes out). I cleaned it out once, looks like I'll be doing it again.
What concerns me is all the slop on the secondary throttle rod, and the gas pouring out of the bores. There's at least a millimeter of movement on the passenger side where the rod enters the carb base.
Bill -
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
10-01-18 01:21 PM - Post#2747628
How old is your gas tank? Any tank that has been left for a long time is subject to corrosion. Any fuel left in it to evaporate can leave residue. Fuel lines too.
That's one possibility. It's one I dealt with on my '63. The new carb, on the new crate engine kept getting 'gunked up'. A very fine residue was getting past the fuel filter and clogging the carb. On my car it was coming from the original gas tank. Blew out and flushed the fuel lines, and replaced the tank and the filter. The carb problem ceased. Can't say that is your problem, but it may be.
Pete
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
10-02-18 05:41 AM - Post#2747680
    In response to japete92
Thanks Pete.
Tank was in the car when I bought it 13 years ago. It's not the original tank, and it's spotless on the outside. It looked pretty clean inside when we dropped it to add the return-style pickup.
Fuel lines are 100% new last Spring, but they're soft lines currently until I can get some custom hard lines made up. They are ethanol safe material, supposedly. I have noticed if I get fuel on the outside sheathing of the fuel lines, it leaves black gunk on my hands. I'm hoping that's not the case with the inside of the lines as well. I haven't noticed any residue buildup inside the carb.
Bill -
Edited by Mr. Sinister on 10-02-18 05:42 AM. Reason for edit: No reason given.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
06-14-19 12:41 PM - Post#2768456
Figured it out finally!!
Wasn't a big enough annoyance to really go nuts chasing it down, but I finally decided to get to the bottom of it the other day.
I noticed it would not do it in reverse, only in forward gears. So I had my wife sit in the car and run it through the gears while holding the brake. When she slid it into drive, there was a noticeable jump in the engine (motor mounts are fine, I checked), enough to jerk the throttle linkage and pull the throttle blades open a hair. The linkage was adjusted too short!! Added a little length to the adjustable linkage and all is well again.
Bill -
Execution time: 0.182 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:36 PM
