Username Post: Ignition Noise on AM Radio        (Topic#352426)
Naldon
Loc: Muscle Shoals,AL
Reg: 07-31-18
08-10-18 10:22 AM - Post#2742614
Trying to keep the car as original as possible, I finally tested and wired in the original AM radio in my 61 Impala. It works fine although there are a limited number of AM stations available in my area. Problem is, for what ever reason, a previous owner has removed all of the RF filter capacitors and associated brackets on the generator, coil and voltage regulator. I haven’t checked to see if the static collector is still installed. Search as I may, I can’t find the capacitors anywhere on-line. Does anyone have a source for these other than a local salvage yards?
Thanks,
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
08-10-18 10:30 AM - Post#2742617
    In response to Naldon
Don,
I'm not aware of a source for new ones unfortunately. Junk yards or ebay are your best bets. Look in your AIM (you DO have one don't you?) and under the radio option, it will give you the correct part numbers. Of course you could buy an NOS radio in the box and it will come with everything.
Verne
DECEASED
08-10-18 01:19 PM - Post#2742627
    In response to Verne_Frantz
Is the capacitance value critical? I was wondering if ignition capacitors would work satisfactorily.
Naldon
Reg: 07-31-18
08-10-18 01:53 PM - Post#2742633
Yes, I have an AIM and thanks.
junky
Loc: Northeast CT
Reg: 06-27-10
08-10-18 05:30 PM - Post#2742657
I have found that all GM cars used them, and the numbers varied as well as the impedance. AM radio is noise prone, even in my 2016 car. Just find what you can from any GM car starting from about 1955 through when they stopped using points, probably in the 1990's. The ones on eBay are extremely expensive, and not worth the money. There is one on the generator, distributor, and the regulator. Also make sure that you have all the grounding straps in place. The collectors in the wheel dust caps are to deal with static from the bearings and tires.
ragtp66
ragtp66
Reg: 12-09-07
08-10-18 08:20 PM - Post#2742673
Scroll Down to Radio Capacitors:
https://www.lectriclimited.com/vehiclesearch/resul...
Toys:
1987 Sea Ray Pachanga 22
Execution time: 0.061 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:53 AM
