Username Post: Socket size for front wheel cylinder bolt?        (Topic#352421)
Novacaine
Loc: IL
Reg: 08-12-09
08-10-18 07:13 AM - Post#2742575
Looks like I'm going to need to get a deep socket to get the front wheel cylinders off. Unfortunately I don't have any that big so will need to pick one up. What size were the stock bolts holding the wheel cylinders on? 15/16? Thanks
1966 Biscayne 2 dr
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
08-11-18 10:56 AM - Post#2742716
    In response to Novacaine
Been a while since, but I'm almost sure there is a 1/2" or 9/16" bolt that holds the wheel cylinder to the backing plate... Hidden behind crud usually.
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
JimKshortstep4x4
Chevytalk Moderator & "15th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
08-11-18 11:57 AM - Post#2742726
The bolts for the front wheel cylinders on my 65 have a 15/16 hex head.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Mercedes
Reg: 07-09-18
08-11-18 12:06 PM - Post#2742727
Don't be surprised if you have to heat them up to get them out. I impacted mine until there was no tomorrow with no luck. Heat did the trick.
fire259
fire259
Loc: No. White Plains, NY 10...
Reg: 06-20-01
08-12-18 07:07 AM - Post#2742807
    In response to Mercedes
I had the same problem on my '65. When you think that it is hot enough, heat it a lot more.
Novacaine
Loc: IL
Reg: 08-12-09
08-15-18 08:41 PM - Post#2743208
    In response to fire259
Thanks guys, I went to Harbor Freight and picked up the right socket based on your recommendations. You guys are going to hate me, but with only a breaker bar I got both front bolts off. Other than brake dust, the inside brake components looked clean with no rust. I don't think they'd ever been replaced nor had this car probably ever seen an IL winter.
1966 Biscayne 2 dr
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
08-16-18 05:54 AM - Post#2743224
I have a 15/16's Deep Socket that I ground flat to get a better bite on the narrow hex of an anchor bolt.
On one of them one day and not wanting to use heat, I finally had to chisel off the wheel cylinder to be able to get a pipe wrench on it with a 6 Ft pipe on my 3/4 Drive breaker bar to finally get it to budge.
I called it the "anchor bolt from hell".
Member:
-National Impala Association
Execution time: 0.061 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:13 AM
