Username Post: 64 impala 409 frame        (Topic#352417)
Black SD
Black SD
Loc: TEXAS
Reg: 06-26-05
08-10-18 03:46 AM - Post#2742553
I acquired an 64 imp ss. After removing the rusted body i found 2 interesting items. 1) it is a factory duel exhaust car with all brackets. 2) on the chassis where the rear arched suspension bar mounts--there is a welded factory brace. This welded brace is shown in the assembly manual but not much wording as what it is or what its function. I was told that this extra brace was attached to the 409 build cars.
Not sure if this is true or not. Comments?
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
08-10-18 03:49 AM - Post#2742555
    In response to Black SD
Post a pic of the brace?
Dual exhaust also came with 327's in 64, you can be confident this was a 327 or 409 car.
Member #2194
Edited by DonSSDD on 08-10-18 03:50 AM. Reason for edit: No reason given.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
08-10-18 06:16 AM - Post#2742577
The extra brace was used on 300hp cars as well as 409 cars. To confirm a 409, look for evidence of a fuel return line or the clip for one above the rear shock tower.
Verne
BTW: The frames themselves were the same, regardless of engine. Either a Budd or Detroit frame, or in the case of a convertible, an A.O. Smith frame.
Edited by Verne_Frantz on 08-10-18 06:19 AM. Reason for edit: No reason given.
Black SD
Black SD
Loc: TEXAS
Reg: 06-26-05
08-10-18 07:07 AM - Post#2742587
    In response to Verne_Frantz
thanks verne
Execution time: 0.059 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:52 AM
