Username Post: Correct 64 exhaust nuts        (Topic#352412)
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
08-09-18 02:27 PM - Post#2742525
Does anyone know which nuts are correct for the exhaust manifold studs. I see some brass and some “locking” type nuts. I blew a donut and when I removed my nuts the RH are locking type and the other side are more standard nuts.
Also there were short (about 2” long)t pipe pieces inside the exhaust pipes. I think they are called down pipe tube extensions. Are these original also?
327/300 engine
Verne??
1964 Impala SS 327/300 since '76
1967 Impala SS 327 Triple Black Hardtop in the works
1967 Impala 327 Bench Seat 4-speed
http://craigaacars.shutterfly.com/pictures
Mercedes
Reg: 07-09-18
08-10-18 05:14 AM - Post#2742567
    In response to Fossil_Fuel
Years ago I had a 64 and the exhaust shop did put the extra sleeve in the front pipe to keep the gaskets from burning up. That's what they told me.
As far as the exhaust manifold nuts, I've seen it a number of ways. I believe that a nut that has a built in shoulder and serrated edge to bite into the cast iron on the manifold is the correct nut.
Edited by Mercedes on 08-10-18 05:15 AM. Reason for edit: No reason given.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
08-10-18 06:13 AM - Post#2742574
These were the original exhaust manifold nuts used.
Verne.
Attachment: ExhaustMan.StudNut.1.JPG (381.76 KB) 12 View(s)
YOUNG57
Loc: Tennessee
Reg: 12-06-10
08-10-18 06:29 AM - Post#2742580
If you blew an exhaust donut why not replace it with a cast iron one. Cast iron ones do not blow or burn out, they last forever unless you drop and break it.
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
08-10-18 08:03 PM - Post#2742670
    In response to Verne_Frantz
Thanks Verne
I think I have the correct ones then.
Attachment: A6328166-60B1-401F-BA14-2943C0948839.jpeg (1.5 MB) 9 View(s)
DougMN
DougMN
Loc: stillwater,mn
Reg: 10-17-02
08-12-18 03:29 PM - Post#2742878
Where do you get the cast iron donuts and what did they originally fit, thanks.
DougMN
Edited by DougMN on 08-12-18 03:30 PM. Reason for edit: No reason given.
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
08-12-18 07:12 PM - Post#2742891
    In response to DougMN
They wern't cast iron; they were a steel sleeve wrapped over an asbestos core. They were found at various auto parts suppliers. I'd suggest an old NAPA dealer. I mean a dealer in a small town that's been there forever.
Verne
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
08-12-18 09:09 PM - Post#2742897
These are the sleeves that were inside my exhaust pipes. Has anyone else seen these?
Attachment: B40676BB-3DCB-4438-9DF0-4B929988411D.jpeg (2.04 MB) 6 View(s)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
08-13-18 03:20 AM - Post#2742908
I have set off my 67 c 20. The ram horns are basic the same for these vehicles.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
08-13-18 04:05 AM - Post#2742914
Those sleeves look like they were cut from a length of steel tubing. I have some original sleeves that GM sold for the Corvair for the same purpose. Later production pipes had the sleeves already installed in the pipes, and those sleeves were not removable. GM probably did the same for the full size cars also, but when was the last time that anyone has seen a NOS pipe, to know for certain?
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
08-13-18 05:48 AM - Post#2742918
yes I have a set myself. One end goes in the pipe and the gasket goes on the other. There used to be a big problem burning out those gaskets and I think they made them to help with that. I forget where I got them but they are available through NAPA or maybe Rock Auto.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
08-13-18 06:50 AM - Post#2742923
Here is a picture of what I have. The gaskets are Sintered metal and the sleeves are stainless for 2 1/2" manifolds. I believe the part number for the gaskets is Felpro 60986 not sure on the sleeves.
Here is one with the graphite gasket and sleeve.
https://www.summitracing.com/parts/aph-9091?seid=s ...
Attachment: gaskets.jpg (1.37 MB) 8 View(s)
Edited by turbo38s10 on 08-13-18 06:59 AM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
08-15-18 07:27 AM - Post#2743125
    In response to turbo38s10
I have always thought the sleeves were to align the donut. It's really hard to get the donut centered, and square in the flange. This always created a leak for me, which led to a burned out donut.
With the pipe inside, it lines up perfectly.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Mercedes
Reg: 07-09-18
08-15-18 03:04 PM - Post#2743180
    In response to beagrizzly
The reason that the exhaust shop installed the sleeves for me many years ago is because the exhaust nuts kept coming loose.
They made them from pipe and expanded one end, I think. They were a tad longer than the kit shown.
I was told that the sleeve would protect the donut from burning out.
Execution time: 0.071 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:12 AM
