Username Post: 3 spd manual question        (Topic#352407)
beachb
Reg: 09-26-17
08-09-18 09:35 AM - Post#2742477
Has anyone seen or heard of rebuilding the standard 3 spd tranny on a 49-52 chevy car with the 3rd gear being a bit taller than what's in there already? I know changing the rear is done a lot but didn't even know if it was possible.
Chevs of the 40s
DECEASED
08-09-18 12:15 PM - Post#2742500
    In response to beachb
No, high gear on a 3 speed trans is always straight through, or 1:1. Of course there are also 3 speed + overdrive transmissions, but to use one of those you would have to convert to open drive.
If you want to keep the stock 3 speed with a torque tube, your only choice for taller gearing is to swap in a powerglide center section. This gives you a 3.55 rear gear and is a very popular swap. You can also get new 3.55 gears from several vendors if you have problems finding an original PG rear.
Chevs of the 40s
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:48 AM
