Username Post: 1990 Chevy G20 - Rough shifting into OD        (Topic#352397)
Ncalexopoulos
Ncalexopoulos
Loc: Florida
Reg: 08-08-18
08-08-18 01:36 PM - Post#2742363
I can’t find anything anywhere about this. I have a 1990 5.7l G20 Van with about 157k miles, complete with a vice grip door handle. She actually runs pretty great for how old she is and how big of a hoot the previous owner was. Anyways, enough with the boring talk... When she shifts out of neutral or park, it’s a pretty hard shift... enough where the brakes barely hold it back from moving an inch in the direction of the gear. It pains me knowing that it’s just slamming into gear. Also, and this is the weird part, in the mornings when she’s cold, she won’t shift into OD (goes into drive fine). I either have to wait for a good 10-15 seconds or rev it a tiny tiny bit and she cluster-pops into gear. Throughout the day it’s fine. Also, when traveling about 50 she keeps shifting in and out of the actual overdrive gear and killing gas. I believe I have the THM350, after much research... and obviously she’s an automatic. The guy I bought it from doesn’t know much and just brushed it off as “oh, the transmission will probably need a rebuild soon” and I won’t accept that. What kinds of things should I check? Could it just be the linkage? Or is it a solenoid possibly? I’ve never adjusted anything like that before and the Haynes manual is not very visual, at all. Also, the other day... and it’s only happened this one time, when my girlfriend shifted it into drive it stalled... she tried it again and it stalled... so I had her get out and I tried it and it worked fine but almost died. It hasn’t been back to that since *knocks on wood* could you guys help me out? If not, and if you can... do any of you guys have a parts compatibility list? Like for the ac pump and what not? I’m very tight on money, and thank you
Blue Willie
1990 Chevy G20 5.7l Conversion Van
Yes, I live in it with my girlfriend
Never pull out
454cid
Loc: West Michigan
Reg: 02-18-12
08-08-18 03:36 PM - Post#2742373
    In response to Ncalexopoulos
  • Ncalexopoulos Said:
..I believe I have the THM350.
The TH350 doesn't have over drive. It's probably a 700R4
99 K3500 RCLB
Ncalexopoulos
Ncalexopoulos
Loc: Florida
Reg: 08-08-18
08-09-18 10:52 AM - Post#2742484
    In response to 454cid
Ah, ok, thank you for that! The guy I bought it from didn’t even know
Blue Willie
Never pull out
DECEASED
08-10-18 10:56 AM - Post#2742608
The fastest way to tell would be to look at the shift quadrant. A TH700 will have an "O" or "OD" position in addition to "D". A TH350 will just have the "D".
Ncalexopoulos
Ncalexopoulos
Loc: Florida
Reg: 08-08-18
08-11-18 12:37 PM - Post#2742732
Yup, do you maybe know why it slams into gear? Is it possibly a solenoid or just an adjustment?
Blue Willie
Never pull out
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
08-11-18 09:21 PM - Post#2742784
Assuming you have the 700-R4, it may simply be the transmission's TV cable is adjusted too tight.
Before you adjust it, just be aware that it is not a kickdown cable. Yes, it does affect the kickdown timing, but more importantly it sets the transmission's internal line pressure. Set it to low and the 700-R4 will die very quickly.
There is lot of discussion in the archives about adjusting it. Personally, I adjust it by how the truck feels/shifts.
- Hammer/very late shifts it's too tight.
- Soft/early shifts with late or no forced kickdown, too loose (and very bad).
- I set it for a good crisp shift at low to part throttle.
With reference to the attached picture,
Red = linkage at TBI
Purple = Depress center metal tab to adjust
Green = Toward TBI for softer shift. Away from TBI for firmer shift.
Attachment: TV_Cable_components.jpg (36.95 KB) 5 View(s)
-91 Sierra C2500, now K2500
-81 Chev K20
Ncalexopoulos
Ncalexopoulos
Loc: Florida
Reg: 08-08-18
08-14-18 07:59 AM - Post#2743032
    In response to stumppuller
Dude, you’re the man, thank you! I knew it was probably something simple to fix. I’ll come back on and let y’all know how that goes today or tomorrow
Blue Willie
Never pull out
Bill K.b
Loc: upstate NY
Reg: 10-24-05
09-03-18 07:18 PM - Post#2745215
GM liked to change stuff every couple years, some parts are like 88-91 only. The cluster is 90-91 only. The exhaust system is different from my 88 to my 91 - the pipes are more or less the same but the hangers are different. The alternators change - my '91 I had a '95 alternator on for a while, but the back of the case is clocked different so the rear bolt couldn't be used. Lots of piddly little stuff like that. Some things you can work around, others you can't. Body panels will swap for virtually any 81-95 van though.
You can get an idea with Rock Auto by looking up specific parts and clicking to see what else it fits. But sometimes the info is wrong. I had fits with my 1991 because the fan belt didn't match what the books say it should have. Turned out a belt for a Suburban fit instead.
There are a lot of parts which will interchange with the squarebody trucks and Suburbans too. For instance the left power window motor in a van is the same as Suburban right rear and (I believe) left front doors.
You asked about the A/C and I never messed with those but it seems like there's two styles of pump, one is larger than the other. Some of the position of the components are different from 88 to 91 also.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
Execution time: 0.068 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:45 AM
