Username Post: 61/62 rear antenna        (Topic#352384)
omarine
Loc: San Diego
Reg: 06-29-15
08-07-18 04:18 PM - Post#2742255
My antenna broke on the 61. Dont need the whole replacement, just the mast.
Does it come apart? And can i replace it with 1963 mast only?
Dont want to spend $68 when the mast is offered for $34, just dont know if its the same internally or not. I thought just the base plate and angle is different.
Thanks!
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
08-07-18 05:56 PM - Post#2742281
    In response to omarine
I don't know the answer to your question, but I have a repop 62 rear antenna less base that you can have for the cost of postage. PM me if interested.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
08-07-18 07:06 PM - Post#2742291
Is your antenna a original rear antenna ? If it is the antenna mast comes out from the upper end. It is seated in the bottom inside of the antenna base on originals.
Used original masts and NOS masts are available.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
pvs409
pvs409
Reg: 01-10-05
08-07-18 10:42 PM - Post#2742304
    In response to pvs409
63 antenna masts are larger diameter (for the rear)
61/62 rear masts are the same.
61 & 62 front antenna original masts are the same(and removalable), not sure on 63 front antenna masts.
picture is of 2 original rear antennas for 61 and 62.
Paul
Attachment: 61-62_NOS_Rear_antennas_007.jpg (163.54 KB) 21 View(s)
61 and 62 NOS original rear antennas disassembled
omarine
Loc: San Diego
Reg: 06-29-15
08-08-18 08:00 AM - Post#2742330
    In response to 55Brodie
Brodie, will send message...
omarine
Loc: San Diego
Reg: 06-29-15
08-08-18 08:03 AM - Post#2742331
Hello Paul, thanks for the info and pictures, my antenna is a repop - supposedly of an original. Came from truck and car shop.
Just replacing the mast would be all I'd need, if my repop doesn't come apart the same way, then I would have to buy the whole assembly which I what I am trying to avoid.
thanks!
Oscar
Execution time: 0.137 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:53 AM
