samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 12:03 PM - Post#2742225
is a 51 station wagon frame and a 51 fleetline frame the same
samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 01:38 PM - Post#2742232
In response to samsonized
I just looked at the parts manual from the old manual project and it answered my question however the manual says a 1951 and a 1952 are different does anyone know what the difference is
DECEASED
08-07-18 02:21 PM - Post#2742239
The significant difference is engine and transmission mounts. Apart from that, they will interchange under either year body.
samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 03:28 PM - Post#2742246
are the body mounts the same
DECEASED
08-07-18 04:01 PM - Post#2742252
Between 51 and 52, the body mounts are the same for the same body styles.
Bel Air kiwi
Reg: 04-24-14
08-07-18 04:10 PM - Post#2742254
To add to what Ray has said. The 51 was the first frame with the tower engine mounts which carried through 53-54. The rest of the 53-4 frame is different from the earlier ones.
The convertible frames are quite unique, and have a complex center brace to support the roofless body.
The Bel Air frame from 50-52 also has some extra internal bracing but looks like a standard frame.
None of the frames have a rear shock cross member and the higher spec GM models all do.
Original frames were designed for 80-150 Hp and low top speeds.
Cheers Kiwi
"They made a desert and called it peace." Tacitus |
samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 04:54 PM - Post#2742266
In response to Bel Air kiwi
would a station wagon body mounts and a fleetline 2 door be the same
samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 04:58 PM - Post#2742268
I am trying to put a 51 fleetline 2 door on a 52 station wagon frame
DECEASED
08-07-18 05:23 PM - Post#2742271
.....The 51 was the first frame with the tower engine mounts which carried through 53-54. The rest of the 53-4 frame is different from the earlier ones.....
Sorry, Kiwi, 52 was the first year for the side mounts.
DECEASED
08-07-18 05:30 PM - Post#2742273
I had to check the parts book for that one because I thought the wagon frame might be different. It's not, though. The frames are the same for all body types except the convertible and hardtop.
samsonized
Loc: chicago area
Reg: 11-08-13
08-07-18 05:39 PM - Post#2742276
should the body mounts be the in the same place
DECEASED
08-07-18 09:45 PM - Post#2742296
They would have to be, because the frames are the same except for the engine and trans mounts.
eplantage
Loc: Southern MN
Reg: 03-15-04
08-08-18 04:41 AM - Post#2742316
Some of the older salvage yards used a Hollander interchange manual. A local yard here helped me find a suitable frame for my '50 sedan delivery. I was a '51 4 door styleline sedan. If you could find one of those manuals that would help. Not sure if they are still published or if they have a website.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe |
samsonized
Loc: chicago area
Reg: 11-08-13
08-08-18 12:31 PM - Post#2742361
In response to eplantage
thanks
Bel Air kiwi
Reg: 04-24-14
08-09-18 02:28 PM - Post#2742526
Hi Ray, My bad, I meant to type 52 and goofed.
The sedan frames should interchange with a station wagon. If there are any changes in body mounts they should be very minor. You can take them off one and put to the other.
As a word of caution, I would always take the donor frame and get it cleaned and primed then put on a chassis table to check it is still square and true.
It's hard to build a straight car on a crooked chassis.
Cheers kiwi
