Username Post: Painting assembly bolts        (Topic#352381)
427_4speed
427_4speed
Reg: 01-31-03
08-07-18 12:11 PM - Post#2742220
I would like to paint the bolts before i assemble my truck. how do you paint them and Keep the paint from chipping off when tightening?
If it ain't broke keep fixing it till it is! That's the Goverment way!
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
08-08-18 08:19 PM - Post#2742410
    In response to 427_4speed
Be very very careful....then touch them up.
Sorry, all I could think of.
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
08-13-18 07:40 AM - Post#2742921
I baked my bolts on my Chevelle. It hardens the paint real good. Bolts still look good to this day. Don't use your everyday oven. I got a used toaster oven to use. Baked at 150-200 degrees for 30 minutes and then let cool in the hot oven.
John H
72 Chevelle-454-4speed
Soon to be 502-5speed
http://www.502malibu.com
2014 GMC Sierra SLT Double Cab
Give Free Food To Rescued Animals Daily
HERE
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
08-20-18 07:09 AM - Post#2743718
    In response to johnhem
I bought a polished stainless bolt kit for the body on my 53 1/2 ton. I think it was $800. Includes all bolts and screws on everything. I am buying the chassis, blower and engine bolts bit by bit, not as painful that way. Polishing the washers is the hardest but my thumb is really shiny.
Mercedes
Reg: 07-09-18
08-20-18 03:03 PM - Post#2743788
I had a friend show me how to put masking tape inside the socket to cushion the metal to metal contact.
It is very easy on bolts.
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
08-22-18 08:03 PM - Post#2744051
    In response to Mercedes
as an example...when I paint oil pan bolts, I cut a piece of cardboard [8x12 or so] punch holes with a phillips and push each bolt in up to the head. dust with silver, wait about 30 minutes [your temp & humidity will vary] and spray a good coat. let dry in sun several days. when using colored paint, which will be thicker, use just enuf dust coats to get good coverage. more paint = easier pealing.
masking tape inside a socket is a good idea. may have to use a metric to get a good fit for some sizes. toaster oven sounds great in high humidity or low temp areas. I painted some and set them out in the 110 degree AZ sun. didnt take long to dry!
FYI. if you have a bolt which will have threads exposed...sand blast [or bead] threads, paint threads with silver. put the bolt in cardboard and paint head whatever color. silver is very thin, stops rust, ages well and will usually go thru a clean nut without problem.
Rod in AZ
Execution time: 0.127 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:43 AM
