Username Post: Replaced oil pressure switch now reading near zero at idle        (Topic#352293)
96hoe
Loc: jax fla
Reg: 12-11-04
08-01-18 03:51 PM - Post#2741719
My oil pressure gauge has been bouncing around for a couple of years. I had a lifetime warranty on the switch so I decided to swap it out.
Prior to the swap the lowest it would read was 20 then max at 60 settle around 40 but would bounce all over the place.
Now with the new one max 40 settle around 20 then drop to near zero at hot idle. No engine noise oil just changed and full on the stick.
Bad new pressure switch? clogged brass elbow?
Any one have this happen. Also there was a plastic nipple in the end of the threaded tube on the new on and no nipple on the old one.
Also new fram extended guard filter. could that be bad?
Edited by 96hoe on 08-01-18 03:53 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-01-18 05:03 PM - Post#2741726
    In response to 96hoe
I dont use Fram. Had bad luck with them
Did you put anything on the threads of the sensor?
If you did that could be your issue
Old School GM fan FOREVER
thx1138v2
Reg: 05-01-14
08-02-18 06:35 AM - Post#2741764
How many miles on it and which engine?
Mine was doing the same thing and I changed the oil to 20W50 high mileage since it's getting up to 225K miles on my '94 4.3L C1500. Now it's ~15-20 PSI at idle when hot.
I've been running it that way for a couple of years now.
454cid
Loc: West Michigan
Reg: 02-18-12
08-02-18 09:43 AM - Post#2741777
    In response to thx1138v2
Heavier oil isn't the solution.
99 K3500 RCLB
454cid
Loc: West Michigan
Reg: 02-18-12
08-02-18 09:48 AM - Post#2741779
My oil pressure bouncing around a little too. I've wondered if it was a grounding issue in the dash. I have not bothered to check into it. You might clean all your grounds under the hood.
I have no idea on the plastic piece. I've never changed the oil pressure sensor before.
How long had it been since you changed your oil? Did you do anything different.... different type/viscosity/additive? Did the old oil look really bad?
No strange sounds is good. If you have a manual oil pressure gauge, or can get one, check the pressure that way.
99 K3500 RCLB
runamukker
Reg: 01-01-18
08-03-18 04:49 AM - Post#2741842
Could be just a difference in ohms from the new sensor, especially if you used a non-GM replacement.
'92 K1500 Blazer Z71 350TBI 700R4 , 253,000 miles
'94 C1500 Cheyenne WT 350TBI 4L60e , 565,000 miles
96hoe
Loc: jax fla
Reg: 12-11-04
08-03-18 10:13 AM - Post#2741867
    In response to runamukker
new oil 10-30. non gm part. auto zone duralast.
went from carquest pro<wix> to Fram.
Although i have used fram on various cars for years with no problem. I am now starting to move away form them, except in this instance. Im not sure how a oil filter would effect oil presure.
Motor has 221K. 5.7 Vortec
Please keep opinions coming. I will be swapping out the pressure switch tomorrow and posting results.
Edited by 96hoe on 08-03-18 10:16 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-03-18 04:03 PM - Post#2741891
stick with wix. Excellent brand for filters
96hoe
Loc: jax fla
Reg: 12-11-04
08-03-18 04:31 PM - Post#2741892
    In response to rockfangd
I forgot to mention I did use teflon tape on the switch end. wrapped two times.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-03-18 05:36 PM - Post#2741900
there you go.
There is not supposed to be anything on those threads.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
08-03-18 05:54 PM - Post#2741901
You might just pull the switch and remove the Teflon.
Greg
'00 Explorer XLT 4.0 V6 Auto
96hoe
Loc: jax fla
Reg: 12-11-04
08-04-18 05:19 AM - Post#2741925
    In response to CowboyTrukr
Teflon removed same results. waiting for it to cool down and pull it to swap out for a new one.
96hoe
Loc: jax fla
Reg: 12-11-04
08-04-18 10:25 AM - Post#2741946
Same result. going to pick and pull in the morning. I did spray carb cleaner in the hole to try to free up any debris before putting new switch in.
If that one doesn't do it I'll change oil filter and add some 20-50 to get pressure up and light off.
454cid
Loc: West Michigan
Reg: 02-18-12
08-04-18 10:35 AM - Post#2741948
You don't need heavy oil. Your engine wasn't built for it, and any extra pressure you get out of it will be feel good oil pressure, not helping your engine oil pressure.
Have you checked your grounds yet? How about a manual gauge?
99 K3500 RCLB
96hoe
Loc: jax fla
Reg: 12-11-04
08-04-18 04:10 PM - Post#2741965
    In response to 454cid
lol I know but it will feel good not to see that gauge at 0.
i wish i never changed out the switch to begin with but, i was tired to watching the needle bounce all over the place. But never below 20.
now I am paranoid.
Edited by 96hoe on 08-04-18 04:10 PM. Reason for edit: No reason given.
Mercedes
Reg: 07-09-18
08-04-18 04:20 PM - Post#2741966
At this point, I would put a mechanical oil pressure gauge in the port and see what the pressure really is. You can keep changing those switches but that is just a way of guessing.
If you had a switch that showed 40 lbs at idle would you believe it?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-04-18 04:44 PM - Post#2741969
    In response to Mercedes
agreed. I would only use a oem pressure sender also.
Been there done that, with the CTS also
Senior Moderator
08-04-18 10:31 PM - Post#2741979
As others have mentioned since you have a questionable situation test it with a mechanical gauge. You can tap in dow ln near the filter. If the mechanical gauge shows good pressure and multiple senders don't fix the gauge, pull the dash lens and adjust the needle to match the mechanical gauge.
96hoe
Loc: jax fla
Reg: 12-11-04
08-05-18 12:41 PM - Post#2742030
    In response to someotherguy
Solved. Although I did not put a mechanical gauge on it. Don't have one. I know, only like $20 at Harbor Freight.
I did get a switch from the pick a part yard that seemed to agree with values the original switch read before I pulled it out. It bottoms out at 20 now.
Thanks for all the input.
Now on to find that exhaust leak from the header install on the RT.
Richard I see you over at the LX forums too.
~SlickAWD
Edited by 96hoe on 08-05-18 12:43 PM. Reason for edit: No reason given.
runamukker
Reg: 01-01-18
08-05-18 02:29 PM - Post#2742038
Is your gauge still bouncing around?
96hoe
Loc: jax fla
Reg: 12-11-04
08-05-18 05:24 PM - Post#2742051
Nope, nice and steady.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-05-18 06:23 PM - Post#2742061
See, they are picky with these aftermarket sensors.
I cant even get into what I went through with the coolant temp sensor. The only way I could fix it was to go to my local yard and pull a used oem one.
All the others readings were like 25-30*off
Mercedes
Reg: 07-09-18
08-07-18 04:38 PM - Post#2742260
I don't know that it is "solved" or you kept looking until you found the answer that you wanted.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
08-07-18 04:45 PM - Post#2742264
I agree. He wanted someone to agree with him from the beginning. I'd be putting a mechanical gauge on it to see what the oil pressure is.
Jeff
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-07-18 05:37 PM - Post#2742274
    In response to bowtie44s
Member installed a oem used one from a pick and pull and it now works properly.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
08-08-18 06:39 AM - Post#2742325
IMHO, 10 pounds of oil pressure sounds about right for a relatively stock hot high mileage engine at idle. Don't know if it is true or not but I've always heard that 10 pounds is enough to turn off a GM idiot light.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
Mercedes
Reg: 07-09-18
08-08-18 02:14 PM - Post#2742372
Swapping over switches until you get the reading that you want is a little like turning over cards until you get the car that you want.
If there is a question about the viability of the switch, then swapping in another switch is not the answer. The switch is supposedly warning of low oil pressure and taking a mechanical reading will verify a faulty switch versus a faulty oil pressure condition.
He didn't want to know about low oil pressure so he kept swapping switches until the problem went away, or so he believes.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-08-18 05:02 PM - Post#2742388
not sure here.
Only way to know would be to put a mechanical gauge in and compare them
454cid
Loc: West Michigan
Reg: 02-18-12
08-08-18 05:26 PM - Post#2742389
I don't think it's that big a deal. The issue started when he changed something electrical, and there was no change in sound. The electrical change can not cause damage to the engine. It would be highly unlikely that an electrical change coincided with a silent mechanical event.
I wouldn't not have been switching sensors that much, However. I would have either lived with the change in oil pressure reading, or I would have gotten a mechanical gauge. When my engine was reading oddly (high) I didn't put a gauge on it. I added Seafoam, and drove it. The pressure eventually went back to normal and the noise went away after startup like normal. Oh, I also changed the filter again. I did have the knowledge that my oil had been changed recently, but had been way too long before that.
99 K3500 RCLB
Execution time: 0.067 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:40 AM
