Username Post: Champion Radiator tranny cooling adaptor        (Topic#352282)
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-01-18 07:03 AM - Post#2741670
I put a Champion radiator, (three core and notched), but the transmission cooling lines need adaptors. I can't be the only one to do this. The steel lines, from Eckler's, are 5/16" with a female end. The radiator is 1/2"-20 straight threads inverted flare. The threads are not pipe threads. I have been looking for a couple weeks, on and off, and haven't found the right adaptor.
Any ideas, or what did you use?
Thanks, in advance for any and all help,
Kurt
1962 Biscayne
Kurt
1962 Biscayne 4 door
1996 Impala SS
2008 Dodge Caliber R/T
2015 Dodge Grand Caravan
2000 Harley Ultra Classic
omarine
Loc: San Diego
Reg: 06-29-15
08-01-18 04:56 PM - Post#2741724
    In response to MrImpala96
Kurt, i just ordered my 2 nd champion. The 3 row notched arrived yesterday.
My 200-4r has the 1/2" male hose fittings.
I have a new 4 row showcars radiator, and it is brass fittngs for trans that have threads in th ID as well as OD.
What trans are you running, PG? Thoought those fittings were standard.
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
impala62
Loc: The Netherlands
Reg: 04-02-07
08-01-18 09:50 PM - Post#2741748
I used these from Ecklers, fits fine with my alu radiator and powerglide cooling lines(also from Ecklers)
Full Size Chevy Transmission To Radiator Cooling Line Fittings, 1958-1972
Part #:
40-246951-1
62 327 4 door hardtop
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-02-18 09:36 AM - Post#2741775
    In response to omarine
omarine,
I have a 700r4, but my problem is not with the transmission fittings, it is with the the aluminum radiator. I have my lines connected to the transmission, just need to connect the lines to the rad.
Kurt
Kurt
1996 Impala SS
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-02-18 09:40 AM - Post#2741776
    In response to impala62
Impala62,
What brand is your radiator. The threads from that connector from Ecklers are pipe threads, at least that is my understanding. My threads for the cooling lines are 1/2"-20 straight threads. Would you be able to check your threads before you install it? If not, no biggie.
Kurt
Kurt
1996 Impala SS
impala62
Reg: 04-02-07
08-02-18 10:30 AM - Post#2741783
The radiator(GPI racing) has straight thread but I tried it and it fitted.
I installed it with some threadsealer and did not use to many force to install it.
It does not leak and is on the road for some time now.
Had to use what was available, very hard to find in the Netherlands.
Ronald
Edited by impala62 on 08-02-18 10:40 AM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
08-04-18 03:40 PM - Post#2741961
I go to the parts house and buy the threaded fitting with barb end to use like this.
https://www.amazon.com/Tru-Flate-21-123-Male -Hose-...
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-06-18 01:34 PM - Post#2742128
    In response to Andy4639
Yeah, not helpful, and wrong threads to boot!
Kurt
1996 Impala SS
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
08-06-18 03:30 PM - Post#2742142
Lategreatchevy.com
part no. 40-246951
$ 4.99 for a pair
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
08-06-18 05:24 PM - Post#2742158
I used the picture as example! I don't know what ends you need. You only know that. I was giving you a idea of the fitting with the barb on it.
Yes it is the right threads for mine.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-08-18 10:03 AM - Post#2742344
    In response to 55Brodie
55 Brodie,
Thanks for the response, but that doesn't fit. On that fitting, the threads into the radiator are pipe threads not straight threads that I need. The other end of that adaptor fits perfect.
Kurt
Kurt
1996 Impala SS
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-08-18 10:05 AM - Post#2742346
Andy,
My first post states exactly what I need, with the exact threads that I need.
Thanks,
Kurt
Kurt
1996 Impala SS
DECEASED
08-08-18 11:23 AM - Post#2742352
Kurt, I expect you may already be aware that the quick and dirty fix would be to cut off the flares on the tube ends, replace the female thread nuts with 5/16" inverted flare nuts, and re-flare the tube ends. Is that fix acceptable to you?
If no, and you will not settle for anything less than the correct adapter, are the female thread nuts SAE flare (45°) or JIC/AN flare (37°)? If you don't know, I would hope that Eckler's should be able to tell you.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
08-08-18 01:19 PM - Post#2742369
EcKlers won't have a clue. Even the small child who manufactured it in China wouldn't know either. Thats the problem when you buy offshore manufactured junk. If it where me I'd ask for my money back and buy a made in USA radiator the next time.
Gary
MrImpala96
Loc: NE Illinois
Reg: 01-06-18
08-09-18 11:38 AM - Post#2742494
    In response to Tri5man
raycow, that is the fitting that I needed, and finally found. And no, Eckler's don't have a clue.
The part number for that fitting is C5880X5 from Eaton Weatherhead. It is Carbon Steel. I didn't even look for any other material. They may have it in SS or brass, I don't know.
SO, if you have a Champion radiator and steel 5/16" tranny cooling lines, this is the adaptor you need. You really don't want to force in NPT threads into a radiator with straight 1/2-20 threads.
Have a good day,
Kurt
Kurt
1996 Impala SS
55Brodie
55Brodie
Reg: 12-26-15
08-09-18 12:35 PM - Post#2742505
Kurt,
did you replace the tube nuts and re-flare the cooling lines tp 37 degrees to use that Weatherhead fitting?
DECEASED
08-10-18 09:22 AM - Post#2742600
Kurt, congrats on finding that adapter. Persistence pays off!
Impalaserg
Impalaserg
Loc: Illinois
Reg: 03-07-12
08-16-18 10:57 AM - Post#2743275
Your local Napa will have the correct fittings
mean60impalagene
Loc: STOCKTON CA.
Reg: 01-31-13
09-01-18 08:58 AM - Post#2745006
Do you have pictures of the fittings ?
Execution time: 0.063 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 AM
