Username Post: '89 S-10 power window problem        (Topic#352158)
matt49
Reg: 05-26-05
07-22-18 08:54 PM - Post#2740851
Hope you good people can help:
Problem: Passenger window is up, won't lower from either switch. Audible click heard with IGN switch on and trying to raise window (it's already up). No click heard when trying to lower window. There is current at one terminal of the switch harness of passenger side.
Driver side window operates fine.
Would a bad driver side switch prevent the passenger side switch from operating?
Would a bad passenger side switch not only not operate from the passenger side (which is obvious) but also cause the driver side passenger window switch to not operate?
Thanks in advance!
Matt ('49 Chevy, '89 S-10, etc.)
07-23-18 06:43 AM - Post#2740872
    In response to matt49
Yes, it can be the drivers switch, they are in series.
matt49
Reg: 05-26-05
07-29-18 02:36 PM - Post#2741420
    In response to acardon
Found it! Broken wire in harness between driver door and chassis!
Matt
Execution time: 0.058 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:33 AM
