Username Post: turn signals for '38        (Topic#352127)
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
07-21-18 05:18 PM - Post#2740711
I am just wondering if anyone out there has added turn signals to a '38, or comparable car. (Or pickup) I was just wondering what the procedure and process is to get something like this done. I am converting to 12v throughout. It sure would be nice to just use the park light socket!
2blu52
2blu52
Reg: 03-12-02
07-21-18 07:12 PM - Post#2740727
    In response to blue_63
you can use the same socket for the rear with stop lights but will have to convert the front to double filament bulbs and a proper socket. 1154 will be the bulb number for 6v 1157 for 12.
THOMAS JEFFERSON
38TownSd
Loc: Bracebridge Ontario Canad...
Reg: 04-04-13
08-13-18 07:05 PM - Post#2742980
    In response to 2blu52
The front parking lights are little bulbs in the headlight buckets. I don't think you want a blinker in there. With the headlights on they wouldn't be seen. My 38 Master has separate lights on the front mounted to the bumper straps.
2blu52
2blu52
Reg: 03-12-02
08-15-18 07:48 AM - Post#2743121
    In response to 38TownSd
Being the former owner of a 38 (first car long ago) I forgot about the location of the parking lights.
THOMAS JEFFERSON
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
08-15-18 08:22 PM - Post#2743207
Yes, if it is a 7 wire switch the present tail light bulbs are used
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
08-18-18 05:46 PM - Post#2743543
    In response to Gene_Schneider
Well, thanks for the replies. I might have to do something for the front. I'm too old to have my arm hanging out the window! I guess there are plenty of options for locations. I was hoping to come up with some sort of plan other than the new-style headlight with the blinker in the bulb.
Greg
DECEASED
08-18-18 10:08 PM - Post#2743571
I found a few pics of 38 Chevys with fender-mounted lights like this. They could be aftermarket instead of OE, but they look sufficiently period-correct IMO. Could you use something like those?
https://www.volocars.com/vehicles/14107/1938-c hevr...
2blu52
2blu52
Reg: 03-12-02
08-19-18 10:31 AM - Post#2743600
They are period correct and a set very similar to that were on the front fenders of my dad's 38 Buick. I seem to recall having seen them on Pontiac s or Olds.
THOMAS JEFFERSON
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
11-03-18 01:51 PM - Post#2750352
Gene, are you talking about the headlight switch? What I am planning on doing is removing one of the 1156 sockets and replace it with an 1157 socket. I should then have what I need. I am converting everything over to 12v, so the wire harness should have tail, brake and turn in it.
Greg
DECEASED
11-03-18 07:06 PM - Post#2750373
I think Gene was talking about the turn signal switch.
Execution time: 0.065 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:42 AM
