Username Post: Check Engine light Question Please?        (Topic#352091)
Willow
Reg: 05-25-12
07-18-18 05:55 PM - Post#2740450
Greetings All:
Question Please: 2012 Silverado 1500 crew cab, 5.3.
Been getting very intermittent check Engine light.
Had auto store run scan, told me speed sensor.
Here’s my problem. Have to make a trip for sick family, probably 450 miles or so round trip. Truck running fine.
Is it safe to make this trip? No light on now as auto store reset. Would appreciate your help as I’m kinda between a rock and hard place. Need to go but don’t need problems.
Thanks in advance
Willow
07-18-18 06:36 PM - Post#2740459
    In response to Willow
What was the code? Look at this. https://www.yourmechanic.com/article/symptoms-of-a ...
Edited by Shepherd on 07-18-18 06:40 PM. Reason for edit: No reason given.
Willow
Reg: 05-25-12
07-18-18 11:16 PM - Post#2740492
Anyone???
Willow
Reg: 05-25-12
07-18-18 11:35 PM - Post#2740494
Don’t know the code. He just said speed sensor and cleared check engine light. Just hoping safe to make trip. Shifting fine, cruise works great, speedo fine. All seems well.
07-19-18 06:05 PM - Post#2740569
Thst link I sent you has all effects of a speed sensor problem.
Willow
Reg: 05-25-12
07-22-18 05:44 PM - Post#2740829
Update:!!!! Drove almost 450 miles with check engine light on .
Everything worked & truck ran great. About 30 miles from my house, Check Engine light goes off? Truck still running
Fine. Everything seems normal?
Regards: Willow 👍😊
Willow
Reg: 05-25-12
07-23-18 02:12 PM - Post#2740920
Update!!!
Damn check engine light just went back on while starting truck and now staying on again. Will have codes run on Wednesday
And write it down to share here. Getting very frustrating!!
YOUNG57
Loc: Tennessee
Reg: 12-06-10
08-10-18 07:46 AM - Post#2742582
My son’s ‘03 Tahoe kept getting intermittent Check Engine light. Some odd functions would not work or come on by themselves like rear wiper, 4WD shifting into 4WD LOW. Turned out to be a failing/dying battery. Started fine every time but apparently it had low voltage. Replaced the battery and all issues went away, go figure ?????
Mercedes
Reg: 07-09-18
08-20-18 04:46 PM - Post#2743798
    In response to YOUNG57
That's actually a common issue on newer vehicles. Unless they have adequate power and amps, systems don't respond well.
I've had the issue on Mercedes where I received strange messages only to have it traced to a failing battery. I did get 12 years service out of the original battery to the car. LOL
Execution time: 0.133 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:37 PM
