Username Post: 2008 Colorado Crew Cab 2.9L Noise on startup        (Topic#352076)
Tyrantosaurus
Reg: 07-17-18
07-17-18 08:47 PM - Post#2740364
Nasty sound on startup in video. Sounds worse occasionally.
https://youtu.be/wNYo1fNpTGs
Usually turnsover 95 percent but sometimes I'll have to crank it again. Sparkplugs/oil filters are new/oil changes about 300 miles before they're due. Currently at 102k miles. Bought it with 77k so I can't speak for how the previous owner treated it. Occasionally on a cold start up it sounds like the engine is sucking in a poopoo tonne of air and doesn't have a lot of power till I go a half a mile or so. My tires are inflated and my blinker fluid is full so I'm all out of ideas? Any help would be great.
07-18-18 04:29 AM - Post#2740378
    In response to Tyrantosaurus
Welcome to the site. Wow, interesting noise. First eliminate any possible air vent motors. Turn off the A/C controls. Does it make the noise if you turn the key to on only? If you have to start it to make the noise, does it do it starting up in neutral?
'08 GMC Acadia 3.6L SLE
Tyrantosaurus
Reg: 07-17-18
07-18-18 11:25 AM - Post#2740412
Still makes the noise when ac is on. At work currently so I'll test the others when I get off.
Edit: And yes the sound sounds like it's coming from the engine itself when it starts up. Same time as its turning over.
Edited by Tyrantosaurus on 07-18-18 11:27 AM. Reason for edit: No reason given.
07-18-18 12:59 PM - Post#2740422
Another thing, I notice dash indicators stay on for a while after starting up. Do light go off? Do any stay on? Seems the gauges also respond slowly. Can you take a longer video?
Execution time: 0.182 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:13 PM
