Username Post: 63 Impala AC blower issue        (Topic#351988)
ampico-kid
Reg: 07-12-17
07-12-18 03:14 PM - Post#2739792
I have a 1963 Impala with factory Deluxe All Weather AC. It's been working fine until today. The blower system works good with the AC off. I get low, medium, and high speeds (blower resistors are fine). When the AC is switched on I only have high speed, the lower speeds are dead. Not sure where to start looking. Hoping it's not behind the glove box (that thing was a bear to get in there). Any advice is welcomed....thanks. Bob
Mercedes
Reg: 07-09-18
07-12-18 04:45 PM - Post#2739798
    In response to ampico-kid
There really isn't a whole lot to this circuit. I wouldn't think that moving the selector switch would change how the blower speed works, but I could be wrong.
Check to make sure that nothing is binding. I would think that the blower speeds are controlled by the switch and resistor regardless of position.
ampico-kid
Reg: 07-12-17
07-12-18 06:32 PM - Post#2739810
    In response to Mercedes
It's not quite that simple. In the AC position the normal "off" position of the blower speed selector is low speed. There has to be some sort of a switchover from standard blower function to AC function, I just don't know where that switchover happens.
models916
Loc: Addison, IL
Reg: 05-28-10
07-13-18 03:59 AM - Post#2739823
Did you check the fuse box. Is it the same fuse for the heater?
ampico-kid
Reg: 07-12-17
07-13-18 06:22 AM - Post#2739838
    In response to models916
Same Fuse for both.
07-13-18 10:46 AM - Post#2739869
There is a switch on the A/C Heater control that redirects power to the resistors and motor. See page 15-34 and 15-35.
Link to A/C manual
ampico-kid
Reg: 07-12-17
07-13-18 02:17 PM - Post#2739896
    In response to acardon
Link to A/C manual
Thanks for the information and the link. Great minds must think alike. I dug out my assembly manual and found the same page that you mentioned in the link. I was really hoping that the switch was not the problem. It's in the worst possible spot to get at, but....I bit the bullet and removed it. It was definitely the switch. The grease inside of it had congealed and prevented the pressure plate from pressing against the switch contacts inside. I cleaned and relubed it and now it works as it should. Thanks for the guidance. It's always appreciated.
Execution time: 0.089 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:22 PM
