Username Post: 1990 GMC Sierra codes 33 and 34        (Topic#351976)
hawk1122
Reg: 10-01-17
07-11-18 01:43 PM - Post#2739713
I have a 1990 GMC Sierra 1500 5.7 L and at least once a week I get either a code 33 or code 34. I know 33 is low vacuum for the map sensor and 34 is high vacuum. I replaced the map sensor and the 2 codes keep coming up once and a while. And it is random with either code (it could be 33 one time and 34 another). It is not persistent however if I shut the truck off for a few minutes the code goes away and doesn’t come back for a week or so. I just want to figure out what could be causing it even though it doesn’t seem to effect how it runs or drives. it is an annoyance having the engine light come on because I have no choice but to check just in case if it is an “actual” problem. Thanks, Hawk
Senior Moderator
07-11-18 02:53 PM - Post#2739724
    In response to hawk1122
I haven't studied the conditions for those codes yet, but I'd start by ensuring the boot at the rear of the TBI isnt cracked or loose. Pretty common once they're this old. You can replace that boot and plastic hose assembly with regular vacuum line, just be sure to route it so it can't kink.
Also check your grounds at and next to the thermostat housing.
hawk1122
Reg: 10-01-17
07-12-18 11:38 AM - Post#2739782
    In response to someotherguy
I will check what you said but also just noticed that the gasket between the throttle body and air filter is pretty bad so this could be the problem.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-12-18 09:29 PM - Post#2739814
It won’t be the cause. These aren’t like the newer trucks that have a closed intake past the MAF.
It could let dirt and moisture in, but it won’t cause the codes.
Greg
'00 Explorer XLT 4.0 V6 Auto
Execution time: 0.077 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:04 AM
