Username Post: 350 chev timing        (Topic#351975)
sniffy444
Loc: wilmer, b.c., canada
Reg: 07-11-18
07-11-18 01:30 PM - Post#2739711
I just put in a new double roller timing chain in a 82 chev 350. I aligned the dots on the timing chain and now the valves keep going 180 degrees out. can someone help?
DECEASED
07-11-18 02:00 PM - Post#2739718
    In response to sniffy444
I can't speak for a roller chain, but with a stock chain the marks on the two gears (sprockets?) should point directly toward each other.
Unfortunately, this can still leave the distributor rotor pointing toward the wrong cylinder. If that's your complaint, then either move all the plug wires 4 spaces on the cap or else raise the dist out of engagement with the cam and rotate the shaft a half turn. If you aren't a purist, move the wires, because there is less chance of screwing up the timing this way.
sniffy444
Reg: 07-11-18
07-11-18 02:13 PM - Post#2739719
thanks. I have tried moving the wires to match the rotor as well as lifting the dist. and rotating the rotor for tdc but it still ends up 180 degrees out when I try to start.
DECEASED
07-11-18 02:19 PM - Post#2739721
I'm sorry, but I am unable to envision the problem as you are describing it, so I suspect that I am not understanding your complaint correctly.
07-11-18 03:43 PM - Post#2739729
When you say the valves are 180 out, that indicates to me the exhaust is opening when the intake should be opening. That would have to be the gears lined up incorrectly. If the distributor is 180 our the fix would be like ray described.
Installing timing set from Summit.
https://www.youtube.com/watch?v=DOdnWggBCUw
29-41, 42-48, 49-54 Moderator
1962 Ranchero Purchased 4/2017 221 V8 Auto. Sold 9/20/18
2013 F150
Senior Chevytalk Moderator
07-12-18 03:04 PM - Post#2739791
Welcome to the site. Anything special about the chain? Some have advanced timing added on them. Were there more than one dot marks? Did the cam gear fit only one way?
Here’s a double roller install: https://youtu.be/C1OrEyzRWck
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
07-12-18 03:25 PM - Post#2739794
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
sniffy444
Reg: 07-11-18
07-12-18 04:12 PM - Post#2739795
thanks again for everyone helping. it was a stock double roller timing set.the cam bearing had only one dot and the main had 3, square for advance and triangle for retard. I aligned the two with the dots.when I try to start it turns over slowly but does not fire.i get #1 piston to TDC and check the dist. and the rotor is off 180 degrees. I lift dist. and turn rotor to #1 piston and try again. it goes back to 180 degrees out. have no idea why.
454cid
Loc: West Michigan
Reg: 02-18-12
07-12-18 10:41 PM - Post#2739818
  • sniffy444 Said:
...I lift dist. and turn rotor to #1 piston and try again. it goes back to 180 degrees out. have no idea why.
What do you mean by "try again"?
99 K3500 RCLB
sniffy444
Reg: 07-11-18
07-13-18 06:51 AM - Post#2739840
    In response to 454cid
try to start again but same slow turning over. check dist. and rotor 180 degrees out again. I did move plug wires on dist. but had same result.
IgnitionMan
Reg: 04-15-05
07-13-18 07:18 AM - Post#2739842
When you TDC, is there compression in cylinder 1, or is it on both valves open overlap TDC?
Also, pull the cal off, grab the rotor and try to turn it, it should only move a short distance, then spring back. IF it goes farther, lull djstributor, check for sheared gear Lin, or possible scroll under rotor loose from the main shaft.
My thought is, you are on overlap TDC, not compression TDC.
Dot to dot, 12 to 6 on the timing chain is TDC overlap, not number 1 compression firing. 12 to 12 is TDC on compression on number 1.
454cid
Loc: West Michigan
Reg: 02-18-12
07-13-18 07:13 PM - Post#2739921
Pull the plugs and spin the engine with the starter... does it turn over at a normal speed? If not, I would suspect you have an starting system problem... bad starter, bad connections, bad battery, something along those lines.
Any chance your valves are adjusted too tightly?... did you mess with them at all?
How are you determining TDC, when adjusting the distributor, and are you turning the engine two rotations when you're finding it out 180 degrees again?
Do you have any instructions for the new gears and chain? Verify the way you're supposed to have the marks on the gears.
99 K3500 RCLB
Edited by 454cid on 07-13-18 07:18 PM. Reason for edit: No reason given.
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:24 AM
