Username Post: 1992 C1500 Finally Running!        (Topic#351972)
Springbank
Reg: 07-23-13
07-11-18 07:03 AM - Post#2739685
Decided to replace the distributor. Replaced it, and the truck fired right up. A close look at the old distributor showed that the plastic fitting that plugs into the ICM had cracked, and one of the wires was totally disconnected. Since it had been running ok, then ran intermittently, I suspect that the connection slowly worked itself loose. Hopefully, this will be it for now.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-11-18 06:11 PM - Post#2739742
    In response to Springbank
Excellent.
Which plug was broke? The pickup one?
Old School GM fan FOREVER
Execution time: 0.071 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:32 AM
