Username Post: Suburban Roof Rack Weight Limit?        (Topic#351966)
sjohns4
Reg: 04-21-16
07-10-18 06:25 PM - Post#2739627
How much weight have you guys put on your Suburban's without doing any damage to the roof?
Thinking of something like loaded coolers which should bear on a few of the pads between the outside rails more so than point loads.
Thanks,
Senior Moderator
07-10-18 08:31 PM - Post#2739642
    In response to sjohns4
This was recently asked on another forum and I suggested it might be in the owner's manual; apparently it is - another member found in his 1998 Suburban manual the recommended limit is 200 lbs.
sjohns4
Reg: 04-21-16
07-15-18 11:13 AM - Post#2740058
    In response to someotherguy
Thanks!
If the book says 200 I bet it'd hold 400...or at least a cooler full of ice & Elk!
Ex Umbra
Reg: 09-22-13
08-06-18 12:37 PM - Post#2742117
At least 1000 lbs. The green bundle on the roof rack in the photo is my 16' x 16' military wall tent. It alone, according to the GI manual weighs 700 lbs. This is a wooden rack I built that merely sits on top of the OEM rack. I traveled from NC to WA and back over 9 months this way. zero trouble.
454cid
Loc: West Michigan
Reg: 02-18-12
08-06-18 01:48 PM - Post#2742130
    In response to Ex Umbra
How do you get a 700lb tent on the roof?
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
08-06-18 05:50 PM - Post#2742159
    In response to 454cid
I was wondering the same thing.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
scrambldcj8
scrambldcj8
Loc: MA
Reg: 04-06-03
08-07-18 04:19 AM - Post#2742190
    In response to bowtie44s
Same here......certainly doesn't "look" like a 700lbs bag....
454cid
Loc: West Michigan
Reg: 02-18-12
08-07-18 08:19 AM - Post#2742202
    In response to scrambldcj8
Maybe it's the armored version
99 K3500 RCLB
Ex Umbra
Reg: 09-22-13
08-10-18 12:09 AM - Post#2742550
One piece at a time.
The end walls come off and are 2 separate pieces The center section is another separate piece. The floor is a separate piece, and all the Aluminum & steel frame pieces are separate pieces. The metal frame sections are not in the green "fabric" bag obviously. They are lying on the floor of the roof rack with everything loaded on top of them. The wood stove disassembles, flu pipes come apart, etc, etc. It's not rocket surgery boys.
Edited by Ex Umbra on 08-10-18 12:16 AM. Reason for edit: No reason given.
Execution time: 0.055 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:19 AM
