Username Post: wiring diagram for lheadlight switch        (Topic#351963)
Fields
Loc: Klamath Falls, OR
Reg: 03-06-17
07-10-18 03:46 PM - Post#2739604
I have converted my 54 to 12 volt, so I ordered a new 12 volt headlight switch, that was suposed to be a replacement, but it isn't the same as original 6 v. I need a diagram with color of wires and where they go on this new switch. I figured if I had the original diagram I could wire the new switch if I had the color of wires and where they go. Any help would be appreciated.
1954 Chevy Bel Air Convertible
Chevs of the 40s
2blu52
2blu52
Reg: 03-12-02
07-10-18 04:00 PM - Post#2739607
    In response to Fields
The on line manual has a wiring diagram, it is not in color but the color and wire size are noted.
THOMAS JEFFERSON
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
07-10-18 06:03 PM - Post#2739625
Here ya go
http://chevy.oldcarmanualproject.com/shop/1949_53/...
Dean50
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
07-10-18 07:42 PM - Post#2739639
    In response to Dean50
Here's a diagram that I made for my '54:
http://www.my54chevy.com/page10/page45/assets/ wire...
Scott Acton
1954 Chevy Bel Air 2-door
07-10-18 10:32 PM - Post#2739650
    In response to dsacton
I always used the original switches when I converted my '53 and '54 cars and trucks to 12V. The originals have very stout copper contacts and will carry 12V with no problem.
DECEASED
07-11-18 12:52 AM - Post#2739654
I agree with rrausch. The switch isn't really voltage-specific. The only likely difference might be the dash rheostat because the 12V bulbs draw less current than 6V.
bobt
Loc: colonial heights va
Reg: 06-28-14
07-11-18 01:38 AM - Post#2739657
When I replaced my old style headlights on my 12 volt 1951 with the new style halogen headlights, I started frying the headlight switch after 3 or 4 months of use. I ended up installing a headlight relay system and that cured my problems. All the switches were 6 volt and with the relay system, I am still using a 6 volt switch.
Chevs of the 40s
Execution time: 0.062 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:15 AM
