Username Post: Carburetor return spring        (Topic#351960)
junky
Loc: Northeast CT
Reg: 06-27-10
07-10-18 11:09 AM - Post#2739572
The spring on my carburetor that pulls the throttle closed when you let your foot off the accelerator, isn't strong enough to pull it back fully. What is the correct spring for this application. 327 Cubic Inch engine 300 HP with a Carter AFB. I do have the throttle return check valve properly adjusted, however, it appears that the car needs a stronger spring.
One other thing about this AFB, is that when the engine is cold, the fast idle is what I believe to be too fast. Once it warms up, a quick tap of the accelerator will cause the engine to drop back to the normal idle. It is just the high idle that I can't find an adjustment for. The carburetor was rebuilt by a highly recommended rebuilder.
Mercedes
Reg: 07-09-18
07-10-18 12:02 PM - Post#2739580
    In response to junky
Disconnect the throttle and see if the throttle blades close on their own. The springs on the throttle shaft should keep things closed. The return spring is designed to give the throttle a bit of feel and return.
My guess is that the springs on the carburetor are not set correctly.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
07-10-18 01:02 PM - Post#2739595
The fasr idle screw is below the linkage on the driver's side and rides on the fast idle cam which is connected to the choke plate via a small round bent rod. The check valve is called a dashpot. How do you know it is adjusted correctly? Were the throttle shaft bores bushed during rebuild? They may need honing/reaming. Or maybe your return spring is just tired.
junky
Loc: Northeast CT
Reg: 06-27-10
07-10-18 02:23 PM - Post#2739597
    In response to 55Brodie
I set the "dashpot" per the manual. I remembered to look up the instructions, but my memory failed me on the correct nomenclature. I don't know if they bushed the shafts, and I will check to see. The throttle moves smoothly, and I am more inclined to believing that it is the spring is tired. Did Chevrolet use a single spring, or was it a spring inside of an outer spring? This is what I have been thinking of using.
I will also check the high idle cam tomorrow when the car is cold. thanks Junk
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
07-10-18 02:42 PM - Post#2739600
Junky,
The'62 assy manual shows 3821966 as the part number for a 300 hp, powerglide car throttle return spring. The PG equipped car has a different pn than the manual shift car. Doc Rebuild has these springs on his website for sale.
Dave
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
07-11-18 02:46 AM - Post#2739661
    In response to dgstarr
I use a spring within another spring. Safety reasons....just saying
55Brodie
55Brodie
Reg: 12-26-15
07-11-18 08:50 AM - Post#2739696
    In response to 1963er
I wear a belt with suspenders.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
07-12-18 05:15 PM - Post#2739803
2X
If your spring is so weak as not to fully close the throttles it may be on the verge of failing or breaking.
The throttles are closed be the throttle return spring. A broken return spring can allow the engine to run uncontrolled at part or full throttle. Using dual springs (spring inside a spring) is just good sense.
models916
Loc: Addison, IL
Reg: 05-28-10
07-13-18 04:03 AM - Post#2739824
    In response to YOUNG57
Throttle return spring on the carb is broken. Little spring on the throttle shaft of the carb.
Mercedes
Reg: 07-09-18
07-13-18 05:30 AM - Post#2739831
    In response to models916
That was my original theory.
Execution time: 0.081 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:42 AM
