Username Post: Vibration        (Topic#351959)
Airlifter
Airlifter
Reg: 06-07-15
07-10-18 10:51 AM - Post#2739570
After the ordeal with the Okie bushing I still have a vibration at 60+ mph. I am pretty sure that it is not in the drive line because when I put the transmission in neutral the vibration goes away. I guess that leaves the engine and transmission. Is there some way to isolate where it is coming from.
I really wanted to keep the car mostly stock and I already have a lot of time and money invested but if I can't find the problem I might start looking for sbc engine start over.
Sorry for the rant and any help and advice appreciated. Pete
1951 styline deluxe sport coupe w/54 engine & powerglide
Chevs of the 40s
DECEASED
07-10-18 11:45 AM - Post#2739577
    In response to Airlifter
Do you get the vibration when you rev the engine with the car standing still?
If yes, did you do anything to the clutch or flywheel when the driveline was apart? Even if you didn't replace anything, did you remove the pressure plate from the flywheel? If yes, did you check for matching punch marks before bolting the pressure plate back on?
Airlifter
Airlifter
Reg: 06-07-15
07-10-18 03:59 PM - Post#2739606
I can't really tell if there is a vibration when I just rev the engine. What I can feel is a little vibration when I put the car in drive. I had felt this before but I thought that it was a problem with the tuning. Carb, ignition etc.
I installed the flex plate to the torque convertor after the engine and transmission was rebuilt. If I remember correctly it was pretty fool proof because of the bolt pattern. I have been driving the car for about a year and a half on and off. About 800 miles.
I didn't notice the vibration until after I changed the rear transmission mount. I replaced the Okie bushing and the Universal joint. That took care of some of the vibration.
DECEASED
07-11-18 12:39 AM - Post#2739653
Sorry, I missed seeing the part about it being a PG. If you feel the vibration only after you put the trans in gear, it's unlikely that you have a balance issue. It sounds like engine roughness, which gets you back to carburetion or ignition again.
My suggestion would be to just drive the car for a while and see if the roughness gets any worse.
Airlifter
Airlifter
Reg: 06-07-15
07-11-18 04:17 AM - Post#2739665
  • raycow Said:
Sorry, I missed seeing the part about it being a PG. If you feel the vibration only after you put the trans in gear, it's unlikely that you have a balance issue. It sounds like engine roughness, which gets you back to carburation or ignition again.
Thanks, that is the plan for now.
Airlifter
Airlifter
Reg: 06-07-15
07-13-18 11:40 AM - Post#2739874
How warm should the ball joint cover and the housing over the u-joint be. About an hour after a drive I was under the car trying to locate the transmission leaks. I laid my and on the torque tube and it seemed pretty warm. The u-joint housing was even hotter. I checked with an infrared sensor and the tempt was 93 at the torque tube and 132 at the u-joint housing.
Is this about normal?
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
07-13-18 01:49 PM - Post#2739890
Did you put transmission fluid in the ball area after reinstalling. You insert fluid thru the speedometer connection. I don't know exact quantity, Just a thought
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
Airlifter
Airlifter
Reg: 06-07-15
07-13-18 02:48 PM - Post#2739900
    In response to one4dad
Should of put that in the post. Yes, I put about a pint of trans. fluid through the speedo cable hole. I also checked to make sure that oil was entering the chamber by running the engine with the transmission in neutral with the cover off.
We ran the car several minutes after we buttoned up everything.
Chevs of the 40s
Execution time: 0.067 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:46 AM
