Username Post: Replacement fuel injectors for 7.4l TBI -1996        (Topic#351953)
65Longroof
65Longroof
Loc: Carlsbad, Ca
Reg: 02-19-13
07-09-18 08:41 PM - Post#2739521
Just looking for advice on replacing the fuel injectors on my k2500 7.4l Suburban. I need to do the Fuel PRessure Regulator so I might as well replace the injectors at the same time.
thanks
Hohnsz71
Platinum Supporting Member
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
07-10-18 07:04 PM - Post#2739634
    In response to 65Longroof
Check your vacuum lines and stick to ac delco Injectors and fel-pro gaskets. Just my 2 cents.
2012 silverado, bone stock.
1997 Suburban k2500, under construction.
454cid
Loc: West Michigan
Reg: 02-18-12
07-10-18 08:22 PM - Post#2739641
    In response to Hohnsz71
The OEM injectors are known to be a bad design. There are lots of vendors on ebay selling new and rebuilt (basically cleaned, I think) Bosch injectors for not all that much money.
It's my understanding that the OEM injectors do not respond well to cleaning.
99 K3500 RCLB
Hohnsz71
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
07-10-18 08:54 PM - Post#2739644
    In response to 454cid
I checked my self, 454 vortec fuel injection and 350 vortec fuel injection are 2 completly different monsters.
454cid
Loc: West Michigan
Reg: 02-18-12
07-10-18 10:26 PM - Post#2739648
Where did anyone mention the 350?
99 K3500 RCLB
Hohnsz71
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
07-11-18 06:36 AM - Post#2739680
I thought that the 454 and the 350 both used spider injectors. that should explain my mistake.
Senior Moderator
07-11-18 07:15 AM - Post#2739687
454cid's comment about the factory injectors is spot-on. They're known as Multecs and do not have a good reputation. I would not replace bad ones with new OR "refurbished" originals. The Bosch 4-hole design has proven to be better though you will pay a premium for them.
Execution time: 0.115 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:14 PM
