Username Post: 1963 400 hp 409 power brake clearance issue        (Topic#351932)
Dave_Neiling
Loc: Custar, Ohio United State...
Reg: 12-10-01
07-08-18 03:39 PM - Post#2739385
I am starting to wonder if power brakes where offered as an option on the HiPo 409 versions. the reason I ask is there is no way to remove the drivers side valve cover with the power brake unit installed.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
07-08-18 06:18 PM - Post#2739404
    In response to Dave_Neiling
Dave,
Power brakes were indeed an option with 409s. I've had luck by turning over the engine so #7 exhaust valve is open.
Other than that, you'll have to loosen the nuts behind the booster and tilt it toward the fender a tad.
I have P/B on my '62 409 and have removed the valve cover many times.
Verne
Dave_Neiling
Reg: 12-10-01
07-09-18 03:54 PM - Post#2739488
    In response to Verne_Frantz
Thanks Verne I'll give it a try.
Execution time: 0.101 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:07 PM
