Username Post: 63 powerglide Reverse light gremlin - ideas?        (Topic#351925)
mshreve1963
Loc: Frisco, TX
Reg: 02-18-13
07-08-18 11:01 AM - Post#2739361
Hi everyone: Hoping someone might have some insight into an electrical gremlin just found in my 63 impala 2-spd auto’s backup lights. I had originally thought that I had a grounding issue preventing the backup lights from illuminating when shifter was put in reverse but the bulbs and wiring are fine; The back up lights GO ON when the transmission is in neutral but they then turn off when in reverse position, so I’m guessing that a relay of some type is faulty.
Could anyone offer some guidance where this relay is located- whether it’s in the steering column by the shifter or down near the transmission case itself? I may be naïve in assuming that these backup lights work on an open circuit like a horn relay does and when the car is put in reverse the circuit is complete and the lights pop on. Regardless, this is a new gremlin for me to attempt to fix and any insight is most welcome and appreciated - thanks very much!
Mark Shreve
1963 Impala 2-Dr Sport Coupe, 327/300 Powerglide
Edited by mshreve1963 on 07-08-18 11:04 AM. Reason for edit: No reason given.
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
07-08-18 11:15 AM - Post#2739364
    In response to mshreve1963
Hello there, my guess would be the neutral safety switch is mis-adjusted or has slipped. Is this a console or column shift car?
Steve Duncan
65 Impala SS Convertible
Ermine White/ Black Top
357 4 spd auto
www.picturetrail.com/steved65
mshreve1963
Loc: Frisco, TX
Reg: 02-18-13
07-08-18 12:44 PM - Post#2739370
    In response to steve65
It’s a column shift 2-spd powerglide. I didn’t even think of that possibility. So that switch is up in column correct? I’d have to sort out how to get in there to check/replace; have not diassembled the column before. Would idea be that by adjusting properly it would bypass the N engage in R, vs. being tripped in N presently? Sorry for geek Q’s!
Mark Shreve
Edited by mshreve1963 on 07-08-18 12:49 PM. Reason for edit: No reason given.
busdriver
busdriver
Loc: Madrid IA
Reg: 05-26-02
07-08-18 02:35 PM - Post#2739378
the switch is under the dash on the outside of the column, two little screws hold in place
Todd
1960 nomad
steve65
steve65
Reg: 09-25-13
07-08-18 06:33 PM - Post#2739406
You might find if the lights come on in neutral that it would/might start in drive. Be carefull.
Steve Duncan
357 4 spd auto
blkss64
Reg: 07-22-12
07-08-18 06:34 PM - Post#2739407
First, check your shift linkage bushings at the lower end of the steering column, close to the firewall. These bushings do wear out. That can be the cause of your problem. If they are intact, then check the adjustment of the neutral safety switch. It is on top of the steering column, under the dash, near the brake light switch area.
mshreve1963
Loc: Frisco, TX
Reg: 02-18-13
07-09-18 04:25 AM - Post#2739423
    In response to blkss64
Excellent thread of advice and much appreciated. I have a few things to check out thanks to you all, and I’ll get under there soon to start inspecting things to hopefully work it out.
Mark Shreve
Execution time: 0.086 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:41 PM
