Username Post: 99 C3500 7.4L RUNNING RICH,RUNS PERFECT NO CODES        (Topic#351920)
99gary
Reg: 07-04-18
07-08-18 06:57 AM - Post#2739343
2wd 4 door longbed
164,000 miles
bought 2 years ago from org owner
my mom got this to pull a med size camp trailer, so it doesn't get used much.
I'm in Calif. so time to smog
won't pass nov 2017 running rich, no codes to say there is a problem.
it runs perfect, starts fast, idles perfect etc.
HC 223 NEEDS TO BE UNDER 100 FAIL
CO .11%, NEEDS TO BE UNDER 1% PASS
$250 in parts my labor
so I do an electrical tune up
+ oil & filter
I replace
all OEM but OX sensors
all 4 OX sensors
water temp sensor
cap
rotor
plugs
wires
check cats, over 100* hotter coming out then going in, GOOD
take back in
July 2018
HC 735, 3 TIMES HIGHER
CO 2.85% 3 TIMES HIGHER
I signed up here to search, have for about a week off and on, seems anyone with rich problem either throws a code or runs rough.
my best guess is injectors, 1 must be hanging open
looked at videos on you tube,not allot of fun to get to injectors,lol
was hoping to not have to spend $400-500 on 8 injectors
I see them from $12 to $90 each
I really don't want a pos injector
what brand part # is recommended by you guys?
read ford f150 yellow injectors, can't remember if there was a part # listed, I think was old post and link to buy was dead
anyway to test them without removing?
ohm test without pulling the intake manifold?
thx in advance for any help
kzhurley
kzhurley
Loc: Millersburg,Ohio
Reg: 01-02-12
07-08-18 05:47 PM - Post#2739399
    In response to 99gary
Had similar issue with mine. Turned out to be 4 leaking injectors and bad fuel pressure regulator. No codes or anything. Just 6mpg.
1950 Styleline Deluxe 2-door sedan..
348 tripower/NP833 4-Speed/3.73
1950 Styleline Deluxe 4-door..
Vortec 4200 I-6/4l60e/3.42/current project car
1956 Cadillac Coupe de Ville 500 efi/4l80e
1987 GMC R1500 Sierra Classic
454 tbi/700r4/3.42
99gary
Reg: 07-04-18
07-09-18 05:36 AM - Post#2739429
    In response to kzhurley
HOW DID YOU DETERMINE THEY were leaking?
pull each one and fill with cleaner and look for drips?
07-09-18 09:17 AM - Post#2739459
Runs that rich and not even pending codes?
99gary
Reg: 07-04-18
07-09-18 10:03 AM - Post#2739462
yes,smog guy can't see why it doesn't throw a code either.
07-09-18 01:18 PM - Post#2739474
Hmm, anybody suggest he calibrate his equipment?
99gary
Reg: 07-04-18
07-09-18 04:10 PM - Post#2739492
2 different machines
I went in TODAY and smogged my 05 ram 1500
in/out 10 minutes pass
Edited by 99gary on 07-09-18 04:11 PM. Reason for edit: No reason given.
07-09-18 05:16 PM - Post#2739499
It's a stretch here but how about the evap cannister loaded with fuel?
99gary
Reg: 07-04-18
07-09-18 05:45 PM - Post#2739502
I will check it out
thx, not thought of that
kzhurley
kzhurley
Reg: 01-02-12
07-10-18 06:21 PM - Post#2739626
I pulled the fuel rail and turned on the key letting the fuel pump prime the system. I ended up buying a set of 8 cleaned and flowmatched bosch injectors on fleabay.
454 tbi/700r4/3.42
99gary
Reg: 07-04-18
07-11-18 04:04 PM - Post#2739734
thx
I went and bought a set of flowmatched bosch injectors on fleabay too:)
$87 for 8, 100% + feedback
I'll check for leaks before I swap them, but it really seems to be the fix as far as I can tell.
thx again, I will update soon
Edited by 99gary on 07-12-18 07:08 AM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
07-11-18 04:18 PM - Post#2739735
$87 for 4, 100% + feedback
You only bought four?
99 K3500 RCLB
99gary
Reg: 07-04-18
07-12-18 07:08 AM - Post#2739771
    In response to 454cid
8
I typed wrong # edited that,lol
99gary
Reg: 07-04-18
11-08-18 01:40 PM - Post#2750795
3 4 MONTHS LATER
i GET TIME TO SWAP ALL 8 INJECTORS
took it in,over 500 hc,over 3% co
rev motor to only like 3k let go & the hcs go to over 3,000
I think I have these HC CO2s right,paper not in front of me.
time to test parts
AFM,TPS??????
Edited by 99gary on 11-09-18 07:49 AM. Reason for edit: No reason given.
Execution time: 0.083 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:20 AM
