Username Post: Hot and cold cylinders?        (Topic#351907)
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-06-18 06:32 PM - Post#2739234
As you may have seen, I have the TPI swapped 87 K5 blazer. I'm still trying to iron things out. One of my issues is (based off the header tube colors) I may have a hot cylinder on #3 and a cold cylinder on #5. I've pulled both plugs and they both look identical in coloring. Both are what I would consider an ideal brownish/tan.
Anyone have any thoughts on this?
Attachment: 20180705_191808.jpg (3.79 MB) 24 View(s)
Attachment: 20180705_191826.jpg (3.7 MB) 20 View(s)
07-07-18 08:05 AM - Post#2739272
    In response to Xray Tedd
Check the tube temps with a infrared thermometer, compare the suspect cylinders to the others, see what you have.
Senior Chevytalk Moderator
07-08-18 10:38 AM - Post#2739355
I agree. Use an infrared thermometer and check each cylinder. If they are within a few degrees, the problem is header coating. All the header will eventually turn that color. I went with ceramic coated headers on my ZZ4.
Are you using stock spark plugs? What's the gap size?
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-09-18 06:24 AM - Post#2739439
The plugs are the Accel R45TS. I have them gapped to .045. I'll have to pick up an IR reader. What temp range should I be looking for? Lowe's has one for $25 but it only goes up to 600*. Would that be high enough?
07-09-18 07:26 AM - Post#2739443
I'm not sure. Let me move your post to the Performance Section. Performance Board users can provide better information.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
07-09-18 07:33 AM - Post#2739445
Last time I hit my headers with IR I was looking at about 730 on a small block.
"8 cylinders of why the f&@% not" - me
07-09-18 09:14 AM - Post#2739456
The actual temp is not point when it comes to looking for a dead cylinder, it is the comparison to the others. Say 6 of the exhaust header temps read at the same point on the pipe are 350, and the other 2 are, say, 250 or lower, that's a problem. Btw, the 600 IR is fine.
Edited by Shepherd on 07-09-18 09:15 AM. Reason for edit: No reason given.
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-09-18 09:27 AM - Post#2739461
Awesome! Thanks guys. I'll pick a reader and report back with my findings. I did take it for a 20 min spin this weekend and then pulled the #1, #2, and #3 plugs. They appear to have leaned out more than I'd like but all three are still consistent in appearance. I got my fuel pressure gauge for my fuel rails in the mail Saturday. I'll get that put on and bump my pressure up a little. Before I was renting the pressure gauge from the Auto Parts store @ $134. So I was always trying to get it returned as quick as possible. I can mount my GoPro under the hood and do a live feed to my phone. That will tell me my fuel pressure while under a load in normal driving conditions.
07-09-18 03:22 PM - Post#2739485
Why do you want to bump the fuel pressure? On a TPI, it should be 43 psi. The ecm calibration is based on that. Don't vary it. If you are using the O2 sensors, bumping the pressure won't richen it anyway except at WOT, because the ecm controls that in real time using the O2 sensors.
Some variation in exhaust temperature, especially at idle, is pretty normal. A dead cylinder will show up quickly.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-09-18 05:59 PM - Post#2739504
Where is your PCV hose hooked to? Carb or intake manifold?
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-10-18 11:21 AM - Post#2739573
    In response to Rick_L
I needed to bump the pressure back up to 43. It was set around 40. Can you elaborate a little more on the dead cylinder?
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-10-18 11:23 AM - Post#2739574
    In response to aghaga
The PCV is connected into the intake manifold. The CCV is hooked to the throttle body.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-10-18 05:44 PM - Post#2739618
Connecting the PCV directly into the intake manifold will cause a lean condition in the port that it is connect to.
07-10-18 06:44 PM - Post#2739628
TPI should have a port in the plenum to connect the pcv which won't affect individual cylinders.
What I meant by the "dead cylinder" is that it will be really cold compared to others.
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-10-18 07:35 PM - Post#2739638
The only vacuum port on the lower manifold had the PCV plugged into it from the factory. Should I change that? My brake booster is plugged into the back of the plenum. I have an IR gun in the mail. It'll be here Thursday so I'll get some readings then.
I really appreciate all the input. Thank you guys!
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
07-13-18 10:00 AM - Post#2739864
I got a chance to get some readings last night. The weather has been a scorcher here in the Ozarks lately. So #s 2,4,6,& 8 are all +/- 10* of each other about 395*-410*. #1 and #7 fall in that range as well. #3 was reading 445* and #5 was reading 388*. So I guess they aren't as far off as they appear in color. I'm wondering if #3 got hot during break in and has since toned down while fine tuning was being done. I don't know how much it matters that there is an inconsistency in those 2 cylinders, but I feel better that it's not as bad as I was imagining.
Is this as good as it's gonna get, or is there anything else I can do/check to get them closer?
I do have what I believe to be a slight vacuum leak. But my brake booster has gone bad since I broke in the engine. The vacuum gauge reads a few lbs less than ideal and there's a very slight idol surge. I'll check the vacuum again once I get the booster replaced.
07-13-18 12:17 PM - Post#2739876
The temperatures may change once you fix your vacuum leak but the range of temperatures you posted is closer together than most engines.
I'm sure these temperatures were measured at idle, which also makes them kind of meaningless in the big picture. They really need to be checked at a higher rpm under load. About the only way to do that is on a dyno.
Checking at idle does tell you if you have a dead cylinder but you don't really need a temp gun for that.
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:04 PM
