Username Post: Odd shifting no power        (Topic#351896)
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
07-06-18 08:27 AM - Post#2739180
95' c1500 350
My girlfriends truck is not shifting correctly and won't rev above 2,000 rpm except in park it will rev fine. Even in neutral it won't go above 2,000 rpm. The trans doesn't want to shift without letting off the throttle, unless you don't go above 1/10th throttle.
Any ideas?
Thanks, Don
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-06-18 09:40 AM - Post#2739187
    In response to Donolie
Have you checked fuel pressure?
Jeff
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
07-06-18 09:41 AM - Post#2739188
Sounds like the transmission has crapped out to be honest. I had a th350 do that to me once with the exception of the rev issue. Refused to shift on the go stick, however that motor and trans had no electronic controls, which could be the rev issue. Any codes?
"8 cylinders of why the f&@% not" - me
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
07-06-18 11:02 AM - Post#2739194
    In response to bowtie44s
I've not checked the fuel pressure. It starts and idels fine.
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
07-06-18 11:04 AM - Post#2739195
    In response to Junkyardwarrior
There are no codes. It almost feels like the TPS has a bad spot causing it to bog past a certain point, but while in park it feels fine.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-06-18 11:08 AM - Post#2739196
If you have 5psi fuel pressure it will probably start and idle fine. It won't show any symptoms and you put a little load on it. Not saying that is your problem, but it's easy to rule it out.
Jeff
07-06-18 11:09 AM - Post#2739197
Clogged cat is another strong possibility.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
07-06-18 12:01 PM - Post#2739203
True. Fuel pressure is a big one. Also in a 95 the only thing it would have a TPS for is the transmission controls. Shouldn't affect the motor revving. To check the catalytic converters, just pull the front 2 O2 sensors out and see if it still misbehaves with the pipes open. It'll be loud but it should give you some clue there.
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
07-06-18 12:33 PM - Post#2739207
I've had test pipe in place of the cat since about 80,000 miles, we are now at about 210,000
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
07-06-18 07:57 PM - Post#2739244
210k on what I'm assuming should be a 4L60. I'm willing to bet the trans is shot. Ever change the tranny fluid?
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
07-07-18 11:57 AM - Post#2739283
I've never changed it. What's odd is last night and today she said it's driving fine. Would low fuel pressure be intermittent? The pump and sending unit we're replaced last summer because of rust.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-07-18 12:21 PM - Post#2739287
Yes, the pressure could be fluctuating.
Greg
'00 Explorer XLT 4.0 V6 Auto
Execution time: 0.068 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 PM
