Username Post: Cone springs on window cranks behind door panels yes or no?        (Topic#351892)
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
07-05-18 07:14 PM - Post#2739121
Got my door panels off to change the lock and handle gaskets with the correct shape early NOS ones I have.
I see the repro parts places selling cone shaped springs to sleeve over the vent and side window regulator crank mounts, and the inside door release handle mount, for behind the panel to push it forward against the cranks and handle.
https://www.ebay.com/itm/1965-Chevy-Impala -Belair-...
They're in the 65 Mustang interior assembly manual, but for 65 full size Chevy too?
Maybe the vendors are just trying to expand their sales base?
Ryan
65 Impala SS convertible 283 2V with Powerglide and 10 bolt 3.08 open
Build date Dec. 21 '64 Oshawa
Jonechev
Jonechev
Loc: Cottage Grove,Minnesota. ...
Reg: 05-03-02
07-05-18 07:30 PM - Post#2739126
    In response to Oshawa65SS
I have taken plenty of these cars apart and can't say I have ever seen those springs on a single one. Not sure why they would advertise them for one either unless their information is just incorrect?
Oshawa65SS
Reg: 09-22-14
07-05-18 07:35 PM - Post#2739127
    In response to Jonechev
Thanks, you're the 3rd no I've heard.
They were a nuisance to install on the Mustang, so there's that, plus one less thing to buy.
Ryan
Oshawa65SS
Reg: 09-22-14
07-05-18 07:39 PM - Post#2739128
Here's another one that I'm thinking no
https://www.ebay.com/itm/64-81-Door-Panel- Window-R...
Ryan
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
07-05-18 11:45 PM - Post#2739144
Ryan
My car (St. Louis built) has these on all 6 cranks, along with the plastic insulator.
I know for a fact that several of my parts cars also had them.
I'll be putting the door panels back on in the next day or so. Will have to look at my tear-down pix for placement.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 One-wheel wonder, 12 bolt
65-66 FSCC #512
Gilly
Gilly
Reg: 09-29-15
07-06-18 04:27 AM - Post#2739157
I was in a LOT of doors in scrap yards through the years, more recently to get regulators to try to fix my brothers 66 convertible (still not sure if we're golden on it!). Anyways, yes almost every broken down old heap we were ripping apart had those conical shaped springs behind the door panels, on everything, except maybe the one for inside door release handle. But definitely the window regulator and vent window. They should be there.
rick1965
Loc: joliet ill
Reg: 12-07-16
07-06-18 05:06 AM - Post#2739162
i would put them back in with the plastic disc unless you want to prematurely snag and tear the vinyl on your door cards. factory installed them for that reason also.
Oshawa65SS
Reg: 09-22-14
07-06-18 07:55 AM - Post#2739178
    In response to rick1965
Thanks for all the feedback everyone
I'll go with the cone springs then
I have the scuff protector discs behind the handles but I'm still thinking no for the foam discs for our cars
As an aside, some of my scuff discs are grey and some are translucent white
I'm guessing different suppliers.
Ryan
Oshawa65SS
Reg: 09-22-14
07-06-18 07:12 PM - Post#2739240
Apparently these are the correct springs with less of a cone shape, who knows?
https://www.ebay.com/itm/1955-67-GM-all-Mo dels-Lar...
Ok, I can see these suiting the side window regulator, but not the vent window and door handle.
Ryan
Edited by Oshawa65SS on 07-06-18 09:56 PM. Reason for edit: No reason given.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
07-10-18 05:28 AM - Post#2739543
Working on my interior and grabbed a quick picture of the old rear quarter panels with the marks on the panels and one of the original springs.
My protectors are gray.
Hope this helps.
Attachment: 4E8B4A8F-1422-4B5A-A80F-380615E03095.jpeg (2.49 MB) 21 View(s)
Kevin
L74 327
M-20
65-66 FSCC #512
Oshawa65SS
Reg: 09-22-14
07-10-18 11:32 AM - Post#2739575
    In response to Gaspains
Thanks for the pics Kevin
I'm ordering the two different types of springs
I see original grey scuff discs may or may not have a second tiny hole, but I haven't seen that being the case with the translucent white ones
Ryan
Execution time: 0.098 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:02 PM
