 Page 2 of 2 <12
Username Post: Evaporator replacement        (Topic#351881)
Kyled1986
Reg: 07-05-18
07-17-18 04:34 PM - Post#2740335
    In response to beagrizzly
This method makes sense to me. I love the way you described it. If I hadn't already charged the system I'd try it. The temperatures I mentioned earlier I cannot seem to replicate neither at idle or highway speeds. When I got to thinking about it I realized while I was charging that I had a fan in front of the condenser and I was continuously spraying it with a water hose to get the system to take the vapor refrigerant. Every since then I have not been able to achieve those same temperatures at the vent. What I do remember is that my head pressure upon stopping the charging process was approximately 160 psi and it was a 95 degree day.
I'm not so sure that I'm not undercharged. What is an appropriate head pressure reading at a 90 or 95 degree ambient? Better yet is there a formula? I know for a fact I don't have a leak and I also know I have adequate airflow over the condenser. I can't check Evap inlet and outlet temps because the orifice tube is installed at a point where half of it is in the engine compartment and the other half is in the Evap box.
By the way...i charged 32 oz into what the OE says is a 44 oz system.
Edited by Kyled1986 on 07-17-18 04:36 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-17-18 07:44 PM - Post#2740357
    In response to Kyled1986
Hmm.
high side is always 1.5 times the ambient temperature
So on a 90* day it would be 90+90+45= 225 psi on the high side.
You may be undercharged.
What is your vent temp currently?
So you put 2.0 lbs which is 32 oz
2.75lbs is 44 oz so if that is correct you are undercharged .75lb. Which is enough to make a difference
Old School GM fan FOREVER
Edited by rockfangd on 07-17-18 07:50 PM. Reason for edit: No reason given.
Kyled1986
Reg: 07-05-18
07-18-18 02:56 AM - Post#2740376
    In response to rockfangd
Thank you. The 1.5 is the number I thought I remembered. Yep, I put 2 lbs exactly in there. I shut the bottle off as soon as the scale read that amount. Originally, GM claims the r-12 charge is 44 oz or 2.75 lbs like you said. My new ac kit came with a charging chart that showed the charge should fall somewhere in between 70% which was 30 oz and 80% which is 36 oz or so. I stopped at 32 oz because I felt I was getting plenty cold vent temps at that point. I was getting 36 at the center vent with blower on max, recirculate on, Windows up, and motor revved to 1200. That was when the head was 160. Now, if I drive the truck down the highway for 15 to 20 minutes in the same heat (95*) I can get to maybe 43-44. At a base idle if I let it run long enough it will get down to 50 at about the best. I know I don't want a very high head pressure but I also know I need a high enough one to deliver as much liquid as possible to the orifice. Also of interest is that at an idle I can hear the orifice tube hissing under the dash. If I raise the idle just a bit the sound goes away. Is this an indication of not enough liquid refrigerant entering the orifice?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-18-18 09:40 AM - Post#2740404
I have always heard 75% 134A of the specified r12. That comes out to 33oz and the gmt400s that came with 134A calls for 2lbs. What is your low side pressure? If it's high, your compressor is bad. If not you are probably just low.
Jeff
Kyled1986
Reg: 07-05-18
07-18-18 11:46 AM - Post#2740415
    In response to bowtie44s
Low side pressure when? At idle? At a certain RPM? As soon as I crank up the AC or after running it for a certain amount of time? Windows up/Windows down? Blower Speed? I always wonder what the conditions are when I read about someone having a certain pressure because we all know these variables can substantially change the readings.
I want to think that the day I charged the system and it was producing 36 degree air that it was right at 20 PSI. Oh and that was with engine at 1200 RPM, blower high, Windows up after I'd been charging for like an hour lol
Edited by Kyled1986 on 07-18-18 11:50 AM. Reason for edit: No reason given.
Kyled1986
Reg: 07-05-18
07-18-18 11:52 AM - Post#2740416
What is a gmt400 btw? I've seen the term but never asked what it meant
454cid
Loc: West Michigan
Reg: 02-18-12
07-18-18 12:42 PM - Post#2740420
It's the truck platform that our trucks are. It tells more about the truck than the year, especially at the beginning or end of that line of trucks. For instance, I have a 99, and everyone knows the GMT-800 started in 99... except, my 99 is a GMT-400, not the 800. The 1-ton's weren't GMT-800s until 2001. If someone says they're working on a GMT-400, there's no room for "well, is that the old body style, or the new body style?". Unfortunately, many people don't know GM platform names.
GMT-400 > GMT-800 > GMT-900 > GMT-K2xx > T1 (2019 I believe) > T2 (in early development?)
The GMT-400 is referred to by many as the 88-98 style, but some earlier Squarebodies (73-87) were still being built through 91... crew cabs, and SUV's.
The GMT-400 was built through 2000. In 99 when the GMT-800 Silverado was made available, it was only 1/2 tons, and light 3/4 tons, the heavy 3/4 and 1-tons were still GMT-400s, and I believe a few GMT-400 1/2 tons were available too. SUVs were GMT-400s through 99... I think.
Also note, that starting with the GMT-800 "Silverado" became a model designation, where it had only been a trim level.
99 K3500 RCLB
Edited by 454cid on 07-18-18 12:58 PM. Reason for edit: No reason given.
Kyled1986
Reg: 07-05-18
07-18-18 06:05 PM - Post#2740452
    In response to 454cid
Thank You! That was a very detailed description. Now I know. I have never understood why GM didn't just bring the new body's in all on the same day...1/2 ton and up all at once.
Edited by Kyled1986 on 07-18-18 06:05 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-18-18 06:17 PM - Post#2740454
Could be just me but I say you are fine with what you have in there now.
The temps are good for the atmosphere.
I would leave it alone and enjoy it
454cid
Loc: West Michigan
Reg: 02-18-12
07-18-18 06:31 PM - Post#2740456
Your welcome.
I would assume changing all truck variations over at once on multiple lines in multiple facilities would be a huge task. Plus the engineering on all variations of the new model may not be done all at once.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-19-18 08:12 AM - Post#2740524
What is your low side pressure when the high side is 160?
Jeff
Kyled1986
Reg: 07-05-18
07-19-18 01:16 PM - Post#2740546
It was 18 to 20 PSI. I just realized that I had the LP switch jumpered out the whole time while I was charging allowing it to pull the pressure down so low while I was trying to add vapor refrigerant. Maybe that explains why it would get so cold that day but not now?
jimshoe52
Reg: 01-08-12
01-30-20 10:20 AM - Post#2785459
    In response to someotherguy
Great pictures and advice. I'm not that auto-inclined. Just curious, what would be the cost to replace evap coil in '90 Chevy C1500?
 Page 2 of 2 <12
Execution time: 0.172 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 AM
