Username Post: Evaporator replacement        (Topic#351881)
Kyled1986
Reg: 07-05-18
07-05-18 08:01 AM - Post#2739047
1990 1500 z71 w/5.7 TBI.I want to replace my evaporator core along with all other AC components. ALLdata tells me that this can be done from the passenger floorboard but everywhere else I look says the whole dash has to come out. Has anyone sucessfully done an evaporator replacement in this model truck? If so does the dash have to be removed or not? Thanks in advance!
Senior Moderator
07-05-18 09:22 AM - Post#2739056
    In response to Kyled1986
Welcome to Chevytalk,
I really don't see how they can make that claim - I'm not 100% sure to say it's impossible so I welcome anyone to offer evidence to support it, but I literally just do not see it. The box needs to be disassembled to get the evaporator core out.
The good news is that on 88-94 it's not a terrible job to get the dash out of the way so you can remove the box. Lower the steering column (don't forget to unclip the gear indicator wire from the column), remove the 5 screws across the top (1 under each speaker grille; pop the grilles up carefully), then 1 bolt under each side behind the kick panels - the dash can be tilted forward and will rest on the studs in the kick panel sheetmetal. Then you can disconnect wiring harnesses and lift the dash out of the truck. May have missed a step or two there but that's the overall picture.
The HVAC box has several screws through the engine side of the firewall. A couple are hidden including several behind the coolant reservoir bottle. Remove all the screws that look like that - the black 10mm head with the large captive washer.
Then on the inside, just to the driver side of the hump in the box that goes over the top of the evaporator core, there's a long 10mm head bolt that has to come out; you'll need a long extension. You can get an idea of its placement by looking on the engine compartment side and see the end of it poking out by the upper connection on the evap.
I've had several of these boxes out and it's no small job but again not a terrible one. It's the same basic process on 95-98 as well just those dashes are more work to remove.
Kyled1986
Reg: 07-05-18
07-05-18 10:16 AM - Post#2739061
    In response to someotherguy
Thank you for your response and the welcome! I have had several others tell me that the dash had to come out as well that is why it surprised me when I found this...
REMOVE OR DISCONNECT
Battery ground cable.
Coolant from the radiator.
Refrigerant from the system.
Coolant overflow tank.
Heater hoses from the coil tubes.
Refrigerant inlet (45) and discharge (46) lines from the evaporator.
Electrical connection to the temperature actuator.
Heater case bottom plate (50).
Remove the seven screws that hold the bottom cover.
Heater core.
Remove the screws and brackets that hold the core to the case.
Evaporator core cover (51).
Remove the four screws that hold the cover to the evaporator case.
Evaporator core.
Pull the core out and down from the evaporator case.
I hope to take a look at it this afternoon and see if this method makes any sense. If it does not I suppose out comes the dash lol. Thanks again man.
Kyled1986
Reg: 07-05-18
07-05-18 11:00 AM - Post#2739065
I guess I should have worded that differently. They didn't actually make the claim that the dash didn't have to be removed, however, they definitely didn't include it in the procedure. Maybe I was supposed to just assume that it had to come out first?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-05-18 01:06 PM - Post#2739077
I did it from the passenger floor board. My box was cracked when I bought the truck so I needed to epoxy it back together. I cut the bottom the rest of the way off, switched the evaporator, and epoxied it back together.
Yes you can cheat like I did, but you should take the dash out. The bottom of mine was almost off to start with so that's why I did it that way. Cutting the rest of the box apart also made it easier to epoxy it back together so I could the epoxy between the joint. There is absolutely no way to get it from the floor without cutting.
Jeff
Kyled1986
Reg: 07-05-18
07-06-18 02:01 AM - Post#2739147
    In response to bowtie44s
Hey Jeff,
Thanks for the response. I took the 6 bolts out yesterday and removed the bottom cover of the HVAC box. There was one screw in the very back that was hard to get to but I finally got it out. I am going to pull the heater core this afternoon to see if I can gain further access to the evaporator core. Can you explain why you say the evaporator can't be removed without removing the dash?
I'm sure once I get the heater core out it will be obvious. I'm just looking for all the insight I can possibly get as I go through the process.
Senior Moderator
07-06-18 03:46 AM - Post#2739153
If you can separate the portion of the HVAC box that has the blower motor housing, you -might- be able to get the job done without pulling the dash. It looks like it could come down to whether you can access all the screws as well as wrangle the parts out.
Here's a view of the blower housing separated from the box, showing the evaporator core (covered in crud) - you can also see the 4 screw positions that hold the two pieces together.
Hope that helps.
Kyled1986
Reg: 07-05-18
07-06-18 03:25 PM - Post#2739223
Nope. Took all those out and still nothing. I believe you are correct in saying that the dash absolutely must come out. I have it half disassembled right now. The rest will come tommorow. It's time for . I do appreciate your help man.
Kyled1986
Reg: 07-05-18
07-09-18 04:05 PM - Post#2739490
Thank you for all the insight Richard. The job is now complete other than charging the system tommorow evening. I'm interested to see how this Sanden compressor performs compared the the R4 that I had. As for anyone who questions whether the dash has to come out in this model truck...absolutely lol
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-09-18 07:37 PM - Post#2739513
I highly recommend that you vacuum for at least 45 minutes. The longer the system is left open the longer it should be vacuumed to boil off any contamination and moisture
Old School GM fan FOREVER
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-09-18 08:33 PM - Post#2739518
Be sure to let us know how the compressor does. What was the part number? Did it bolt right on?
Jeff
Kyled1986
Reg: 07-05-18
07-10-18 06:25 AM - Post#2739544
    In response to rockfangd
I vacuumed for about an hour and it held overnight amazingly. That's pretty good in my book lol.
Kyled1986
Reg: 07-05-18
07-10-18 06:28 AM - Post#2739545
I sure will. Not sure on the part number. I ordered a total kit. It comes with brackets to bolt the compressor on. Here is the link https://www.originalair.com/88-90-chevrolet-truck -...
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-10-18 07:42 AM - Post#2739558
That's really a good price for everything you're getting. I'm anxious to hear how it works and what your vent temps are.
Jeff
Kyled1986
Reg: 07-05-18
07-10-18 12:52 PM - Post#2739593
I will definitely let y'all know. Any advice on charging? It come with a charging chart stating between 70 to 80% of factory r12 charge. I have a 30lb cylinder and scales. Question is...when is enough? I'm used to charging by exact weight. This is going to be a little different.
Kyled1986
Reg: 07-05-18
07-10-18 12:58 PM - Post#2739594
Oh, one more thing. The paperwork that came with the compressor says that I need to rotate the compressor clutch manually by hand 10 times to clear all the oil from the compressor head. I'm a pretty big guy but I cannot move it by hand at all. Any ideas there? I had thought about bumping the a.c. button a time or 2 really quickly to accomplish this before I charge it. Would that work?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-10-18 03:48 PM - Post#2739605
I always spin the compressor by hand to spread the oil so the compressor doesn't hydro lock. Like you, I had one that wouldn't. I locked the clutch figuring the belt would slip but it turned and worked fine ever since. Did you put all 8oz of oil in the compressor or did you put some in the accumulator and/or condenser?
You need 2lbs or 32 ounces. Weigh your container and stop when it's 2lbs lighter.
Jeff
Edited by bowtie44s on 07-10-18 03:50 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-10-18 07:03 PM - Post#2739633
If the compressor is already installed cycle the ac a few times. Then try turning it by hand.
There may be some paint on the clutch or just tight. Should be fine
Kyled1986
Reg: 07-05-18
07-11-18 03:00 AM - Post#2739662
Actually the compressor come precharged with 135cc or approximately 4.5 oz. The instructions with the kit says that this is a full charge of oil and specifically say not to add any oil to the system. I know originally the system takes 8 oz. Now I am confused.
Kyled1986
Reg: 07-05-18
07-11-18 06:04 AM - Post#2739676
Alright. I'll do it that way. Thanks!
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-11-18 08:04 AM - Post#2739690
Evidently the new style compressor doesn't need as much oil as the pancake compressor.
Jeff
Kyled1986
Reg: 07-05-18
07-11-18 01:58 PM - Post#2739717
Just charged 2 lbs into it. Vent temp @ center vent it between 36 and 38 degrees sitting still revved up to 1200 rpm. It's 95 degree ambient right now at about 75% humidity
Edited by Kyled1986 on 07-11-18 02:00 PM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-11-18 02:42 PM - Post#2739723
That is outstanding. My pancake compressor only gets 55°-50° on these 95° days.
Jeff
Kyled1986
Reg: 07-05-18
07-11-18 03:47 PM - Post#2739731
Man I am amazed myself. This is a world of difference. Prior to installing this kit I had the same temps that you did. The new kit had me relocated the orifice tube to the evaporator inlet. I can hear it pulsing now. Is that out of the ordinary?
Kyled1986
Reg: 07-05-18
07-11-18 03:52 PM - Post#2739732
By the way...where did you come up with the 2lb number just outta curiousity?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
07-11-18 05:13 PM - Post#2739738
The 94 and newer trucks that originally came with R134A have the sticker under the hood that says 2lbs.
Did you have to buy the whole kit? I just changed everything a few years ago. Condenser, evaporator, compressor, accumulator, hoses. If upgrading the compressor would gain 15°-20° I'd do it.
Jeff
Kyled1986
Reg: 07-05-18
07-11-18 05:58 PM - Post#2739741
No you don't. They will sell you whatever you want. They have a kit that is compressor upgrade only. The only reason that I replaced everything is because i have been fighting with trying to get this system to cool like it should for 2 years now with no luck. I figured if I threw a whole new system at it that it would work. I got lucky. Plus I figured it wouldn't hurt to swap out a 28 yr old evaporator lol.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-11-18 06:15 PM - Post#2739743
great to hear.
Those are perfect temps. Dont want much colder than that.
you got lucky with the oil in the compressor.
Some come precharged. some have shipment oil that has to be swapped out and refilled. Some have none.
My 1990 had 55/2 but since I swapped cabs now I hav e55/3 because of the slifing back window lol
Edited by rockfangd on 07-11-18 06:17 PM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
07-12-18 08:04 AM - Post#2739775
Kyled,
I was a heavy equipment mechanic for 30 years, and I have stumbled on a charging system that works for virtually everything I have worked on.
Some large equipment has a lot of hose. Sometimes the unit is on top of the cab and may have 10-12 feet of hose to the compressor.
1. Perform all necessary repairs.
2. Connect gauges normally.
3. Vacuum per usual procedure.
4. Connect the bottle to the gauges.
5. Close both valves.
DO NOT START THE ENGINE!!
6. Turn bottle upside down so you get liquid only.
7. Open the HIGH PRESSURE valve.
8. Watch the gauges closely.
9. Immediately shut the high pressure valve when the system equalizes between high, and low pressure.
10. Turn the bottle back over.
11. Give it 5 minutes and start engine.
The system should be charged within a couple of ounces.
This does a couple of things. You are filling the liquid line, and pushing vapor across the orifice. As you watch the low pressure gauge you can tell if the orifice is operating correctly.
It also is filling the line that should be liquid during operation.
Yes, I know, "never charge liquid" (you'll lock the compressor up.
"Never open the high pressure side". You'll blow it up.
The system is down. Do NOT do this with the engine running!
This is a major time saver. Anyone that has ever tried to completely charge a new system using vapor only knows that you can grow old waiting.
Griff
Yes, I already know. There are going to be tons of naysayers shooting holes in my suggestion. As stated previously, I have worked on everything from Cats to Komatsus with Chevrolets, and Hyundais, even a couple of Fords.
I am IMACA certified, and I have done dozens of systems. This works.
So, that said, please don't state that it won't work unless you have tried it.
I'm not trying to be a jerk, but I don't need any theories, or opinions.
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-12-18 05:46 PM - Post#2739808
    In response to beagrizzly
Love your response.
I deal with full size buses and They have alot of plumbing with their rooftop or skirt condensers.
Especially when the bus is 48 ft long. So there are hoses running to both the AC unit evaporator, and all the way to the condenser unit.
When I see a system that big that shows a proper charge of anything less than 5lbs or freon I call BS, and have proved it many times.
You talk about time. These new AC machines are absolutely ridiculous. They do all kinds of useless crap that you cannot control. Takes at least 1 hour to do a 15 minute job. Damn EPA
Execution time: 0.175 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:50 PM
