Username Post: Front brakes pulling        (Topic#351867)
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-04-18 09:30 AM - Post#2738940
I have a 63 Impala SS. A while back it started pulling to the right when I applied the brakes but not too bad. By the way I have 4 wheel factory brakes.
Now it pulls left much worse.
I just finished taking the left wheel off and examining it to see if brake fluid was on the left brake shoes. There is no sign of fluid. I also tried to wiggle the tire back and forth horizontally to see if there was any indication of worn stuff that I could easily see but the wheel didn't move a bit. The brakes are adjusted right up against the drum if that makes any difference.
Anybody got any idea what might be making it pull when brakes are applied? By the way, I don't know if it pulls right anymore since it goes left much more than it ever did right.
George
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
07-04-18 09:53 AM - Post#2738941
    In response to gkralik3645
One possibility might be the flexible hoses deteriorating from the inside and blocking fluid from flowing to the wheel cylinder. A fairly inexpensive fix.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-04-18 12:52 PM - Post#2738950
    In response to 55Brodie
I guess that is one easy thing to try. Will get new hoses tomorrow and work on it. Thanks for the response.
George
55Brodie
55Brodie
Reg: 12-26-15
07-04-18 04:38 PM - Post#2738976
You can check the flow before you buy new hoses by cracling the bleeders and observing.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-05-18 04:21 AM - Post#2739022
ok
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-05-18 07:27 AM - Post#2739039
I loosened both front bleeders and fluid ran out freely as if you were bleeding them so I don't think the hoses are deteriorated inside. Now I don't know what to think. The right brake is adjusted just a little tighter than the left but the left is the one pulling.
George
cowfarmer350
Reg: 02-03-01
07-05-18 11:43 AM - Post#2739070
Have you checked the wheel cylinders, if they rust one side can seize and not apply equal pressure to both shoes , are the drums within max wear spec, when was the last time you did a full brake job on the car
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-05-18 11:50 AM - Post#2739071
    In response to cowfarmer350
I have not checked the wheel cylinders. I purchased the car 4 years ago. I have put only two thousand miles on it since. I can tell when I had the brake drums off that the shoes are new.
They have essentially no wear at all.
George
55Brodie
55Brodie
Reg: 12-26-15
07-05-18 01:21 PM - Post#2739079
As Cowfarmer said, check for frozen wheel cylinder.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-05-18 01:57 PM - Post#2739088
If one is frozen, it would be the one not dragging, right?
That is my assumption, however that is the one dragging originally. I will check it out anyway.
George
Brian64SS
Brian64SS
Loc: Milwaukee, Wi
Reg: 09-30-00
07-05-18 02:56 PM - Post#2739092
Brake fluid absorbs water and turns the insides of wheel cylinders into a gritty, sticky substance over a few years. Fluid might still flow through during bleeding but they should be rebuilt or replaced. It isn't hard to do. The rears have two small bolts from the back and the fronts have one big one above. The worst part can be getting them off the car. Heating with a torch can be needed and propane isn't usually hot enough.
Brian
1964 Impala SS, 283 (not original), 4-speed (26 years)
1964 Impala 4-door hardtop, 283 Powerglide (3 years)
They made a million but I only have two.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-05-18 07:17 PM - Post#2739122
could be the wheel cylinder. it will be the one opposite the side that is pulling due to it not working as well as the other one
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
models916
Loc: Addison, IL
Reg: 05-28-10
07-06-18 05:14 AM - Post#2739163
    In response to 62chevy427
Just change the hoses.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
07-06-18 06:25 AM - Post#2739170
    In response to models916
Take the drums off and go see if they are beyond the wear limit,happened to mine. I replace the front drums and now pulls evenly while I was there I cleaned and honed the cylinders.I had purchased brake drums from Sumitt which were Bendix brand drums. 1 drum was warped from the get go they shipped another out no problem and it was bad also finally got a good 1 and all is good now.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Edited by 69_BOWTIE on 07-06-18 06:25 AM. Reason for edit: No reason given.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-06-18 01:25 PM - Post#2739209
I bought the hoses today. Will put them on tomorrow and hope for the best. Thanks for the help.
George
junky
Loc: Northeast CT
Reg: 06-27-10
07-06-18 02:06 PM - Post#2739213
If you hone the wheel cylinders, make sure to wash them thoroughly inside with dish washing liquid and to rinse in hot water. Blow dry, and then assemble with new parts dipped in either assembly lube or the brake fluid that you are using in your system. If you don't do this, will result in the new rubber cups to fail prematurely.
Cleaning with brake cleaning fluids will not remove the microscopic metal residue from the honing.
Edited by junky on 07-06-18 02:07 PM. Reason for edit: No reason given.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-07-18 04:46 AM - Post#2739260
    In response to junky
OK thanks.
But now I must say I am really confused. Last night our club went on a dinner cruise of about 25 miles out and 25 miles back. On the way back I had the opportunity to test my brakes several times with a few hard stops. It seems that the pulling has disappeared, at least temporarily anyway. I was driving between 60 and 70 miles an hour on my way home.
Now I am wondering if it could be related to the tires in any way. They are Hanyo or something like that, that I purchased new. They have about 500 miles on them.
George
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
07-07-18 02:42 PM - Post#2739297
Went on another 50 mile drive today. Same speeds as last night. No brake pulling again. I asked a friend who has much more knowledge than I do and has rebuild many cars what he thought. He said probably some dust in a brake drum had hardened and now has broken loose. I can accept that as I don't have a problem any longer.
Thanks to everyone with your attempts and clues to fix my problem.
George
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:21 PM
