Username Post: Crossmember on '58        (Topic#351833)
58 Delray
Reg: 01-04-07
07-02-18 03:06 PM - Post#2738747
Does the crossmember have any adjustment options or is in a fixed position?
Bob
Edited by 58 Delray on 07-02-18 03:06 PM. Reason for edit: No reason given.
DECEASED
07-02-18 11:07 PM - Post#2738774
    In response to 58 Delray
Are you asking about the crossmember the transmission mounts on and are you asking because you are swapping in a different transmission with a different mounting pad location? If yes, there is no adjustment for the fore and aft position.
Your options are to buy an aftermarket "swap" crossmember, fab a new crossmember yourself, or modify the one you have now.
58 Delray
Reg: 01-04-07
07-03-18 02:55 PM - Post#2738839
Yes swapping a 235 cid and power glide for a 327 cid and turbo 350.
Bob
ragtp66
ragtp66
Reg: 12-09-07
07-05-18 09:03 PM - Post#2739138
Well depending on WHICH turbo 350 your using (which tailshaft length) you can use the PG crossmember. The crossmember gets installed in the lower holes for the auto trans. The cross member also is slanted and for the life of me I cannot remember which way the slant goes at the moment. My gut feeling says it goes to the rear of the car. I am sure someone will correct me if I am wrong.
Toys:
1987 Sea Ray Pachanga 22
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
07-06-18 11:23 AM - Post#2739201
    In response to ragtp66
Yes, a TH350 with a 6" tail shaft will mount on the original crossmember.
When I got my Delray, it has a 350/TH350 combination and was mounted on the original crossmember. The short tail shaft helps with the front half of the driveshaft. Less to shorten.
ragtp66,
I believe you are correct that the slant go towards the back. helps with leveling the engine.
58 Delray in disaray
Execution time: 0.087 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:58 PM
