Username Post: Location of A/C pressure sensor        (Topic#351799)
KOOL57
KOOL57
Loc: Fargo, ND
Reg: 01-04-03
06-29-18 05:40 PM - Post#2738552
Duplicate of my post in MonteCarlo section. The Lumina (& maybe other models) should be the same.
1998 Monte Carlo 3.1V6.
Air Conditioner quit working. Compressor does not engage.
Thought I'd try a Haynes suggestion and force compressor on for a minute-see if it cools by using a jumper wire across the terminals of the low pressure sensor.
Where is this sensor? Haynes manual says its on the evaporator inlet line. I can see where the tubing enters the cabin-back behind the engine. And can (barely) see the 2 service ports down below the air cleaner. Can't see any switch.
My question today is: Where is this low pressure switch (sensor)?
SteveS
"If it ain't got fins, it ain't a real car!
Edited by KOOL57 on 06-29-18 05:42 PM. Reason for edit: No reason given.
KOOL57
KOOL57
Loc: Fargo, ND
Reg: 01-04-03
07-02-18 11:48 AM - Post#2738735
    In response to KOOL57
Followup to my above post:
There is a fuse box on the passenger side of the engine compartment.
Most of the printing is worn off. Could someone tell me what each of
the fuses/relays are for. Or maybe a closeup pic of the cover.
Tanks. SteveS
Bruce30
Reg: 11-24-16
07-14-19 11:34 AM - Post#2770682
sounds like same issue I have with 2001 impala fuse box lid. My bottom half is a ghost image. I know something there but cant read
Execution time: 0.124 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:01 AM
