Username Post: Distributor Bracket Hold down Bolt        (Topic#351618)
Camaro86
Loc: Akron,Pa. 17501
Reg: 06-18-18
06-18-18 07:57 AM - Post#2737360
Anybody out there know the exact size of the distributor hold-down bracket bolt on a 86 Camaro 2.8 FI V6?
Junk86
Reg: 03-15-19
03-17-19 01:45 AM - Post#2762277
    In response to Camaro86
I believe it is 9/16. My whole bracket and bolt fell down on top of the transmission housing and I was unable to retrieve it. Went to autozone and bought a chrome hold down bracket with bolt for a 350 sbc and it worked out fine. I also did manage to locate another set used on e-bay. Just make sure the bracket and bolt are properly installed and tight, so the distributor shaft can not pop out.
Junk86
Reg: 03-15-19
03-17-19 08:45 AM - Post#2762298
I gave you the wrong information. That bolt is 14mm .
I had to buy a distributor wrench specifically for that application. My 9/16 would not work. Sorry about the incorrect reply.
Execution time: 0.176 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:49 PM
