Username Post: Bleeding my brakes.        (Topic#351610)
MINIGUN
Reg: 06-17-18
06-17-18 05:04 PM - Post#2737300
I have a 1970, 350, 4-speed, 4x4, 1/2 ton short bed step side, all manual truck. Just put in new suspension and new extended brake hoses. fluid flows freely down new hoses to the wheel cylinders. For the life of me, I can not get the fluid to go into the wheel cylinders and come out the bleeders. I remember in the past they only needed to gravity bleed. The drums lock up when you apply the brakes, so something is moving in there. Have my son pump up the brakes, I open the bleeder and nothing? Frustrated to say the least.
THX.
JimKshortstep4x4
Chevytalk Moderator & "16th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-18-18 04:20 AM - Post#2737330
    In response to MINIGUN
Welcome to Chevy Talk from West Michigan!
Bleeding brakes can be a challenge at times!
I assume the bleeders are not plugged and I assumed that you bench bled the master cylinder so I would start with the proportioning valve and bleed both ends. From there I would lock the valve open for the rear and bleed the rear first. Hopefully gravity bleeding will work. Once the rear is done, lock the front and bleed the front brakes.
I don't understand why gravity bleeding did not work for you on all four wheels, but I wonder if you gave it enough time. Is the master cylinder new? It is rare but sometimes master cylinders have problems.
Good luck and stay patient!
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
06-18-18 08:41 AM - Post#2737359
Welcome to ChevyTalk.
29-41, 42-48, 49-54 Moderator
MINIGUN
Reg: 06-17-18
06-19-18 05:10 PM - Post#2737580
I'll start over again and bleed the master cylinder. It is the old one, might even be the original. My dad took good care of the truck. He generally used rebuild kits. So hopefully this weekend.
Thx
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-20-18 07:37 AM - Post#2737658
Take the hoses loose at the backing plates and push the brake pedal. That will tell you if your getting fluid to the wheel. Take one loose at a time and try it.
Did you buy new wheel cylinders? You may have trash in them. You may also have air in the system.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 06-20-18 07:38 AM. Reason for edit: No reason given.
bry593
Reg: 10-07-13
07-13-18 10:42 AM - Post#2739859
    In response to Andy4639
First thing to do is remove the bleeder valve completely and observe if fluid begins to leak out. It should definitely gravity flow out unless you have a restriction between the master and wheel cylinder. Most likely, the hole in your bleeder valve is rusted shut. Pretty common. When you have that bleeder valve out, see if you can blow through it.
Mercedes
Reg: 07-09-18
08-12-18 02:06 PM - Post#2742861
In my experience, the best way to bleed air from brake systems is to first make sure that you properly bench-bleed the master cylinder. This step is very important.
Next, I vacuum bleed the system starting with the wheel furthest away, then closer, etc. You need to keep the reservoir full as you do this.
Vacuum bleeding is the easiest way to get the fluid to come through.
Wrap all of the threads on the bleeder screws with teflon tape to avoid sucking air around the threads.
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:56 AM
