Username Post: Wilwood brakes,66 impala        (Topic#351379)
wch
Loc: TX
Reg: 05-13-17
06-01-18 10:31 AM - Post#2735600
I have just completed a front disk brake conversion on my 66 Impala. I used the Wilwood front wheel kit for use with stock spindles. I could not be more happy with the results. All the parts are very high quality.
the kit has 12.19" rotors and fixed 4 piston calipers. The more I use them and the more the pads and rotors break in the better they work ! Great way to convert to front disk brakes !
The picture shown is with my 18" wheels. I have tried a late model gm 15" wheel and they work also.
another note is that this kit does not change the wheel offset as with many of the kits for use with stock spindles
Casey
1966 Impala,2dr,283,PG
Edited by wch on 06-02-18 06:48 AM. Reason for edit: No reason given.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
06-02-18 10:49 AM - Post#2735687
    In response to wch
Great idea and they look mighty fine, thanks for sharing...
...Ed
1965 Impala SS
Michaelq
Reg: 03-14-18
06-02-18 11:57 AM - Post#2735695
    In response to wch
That looks great. What model # are they? I’m want to install them on my 1966 Caprice. I was ordered CPP big brakes front but the caliper brake bracket are on back order. They couldn’t give me firm date when they will be in stock. This looks like a better solution.
Michael
1966 Caprice
06-02-18 01:38 PM - Post#2735700
    In response to Michaelq
Waited almost 2 months for caliper brackets for a 55 Ford, from CPP!
wch
Loc: TX
Reg: 05-13-17
06-04-18 02:26 AM - Post#2735868
Thank you !....the Wilwood wheel kit is part #140-12022
Casey
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
06-04-18 02:58 AM - Post#2735869
    In response to wch
Did you use the stock spindals?
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
wch
Loc: TX
Reg: 05-13-17
06-04-18 08:25 AM - Post#2735887
    In response to HAL_396
Yes sir, it uses stock spindles. That was one of the things I liked about this kit. The hubs that come with it are specific to 65-68 with the small bearings.
Casey
wch
Loc: TX
Reg: 05-13-17
06-04-18 10:15 AM - Post#2735893
    In response to wch
there is a six piston option available also
Casey
Michaelq
Reg: 03-14-18
06-05-18 08:15 AM - Post#2736016
    In response to wch
Did you use the brake line kit pn# 220-8307?
Michael
1966 Caprice
wch
Loc: TX
Reg: 05-13-17
06-05-18 10:24 AM - Post#2736033
yes
Casey
Michaelq
Reg: 03-14-18
06-05-18 01:09 PM - Post#2736044
    In response to wch
I ordered the same except for drilled rotors. Thanks for the info!
Michael
1966 Caprice
wch
Loc: TX
Reg: 05-13-17
06-10-18 09:56 AM - Post#2736512
converted to Non-power "manual brakes" . Works great with the Wilwood setup. Very little pedal effort.
Casey
Michaelq
Reg: 03-14-18
06-13-18 08:39 PM - Post#2736910
    In response to wch
My brakes just got in. Did your car have power brakes and you converted to manual? Also are you still using the rear drum brakes? My Caprice has power drum brakes. The firewall looks cleaner without the power booster.
Michael
1966 Caprice
wch
Loc: TX
Reg: 05-13-17
06-14-18 08:01 PM - Post#2736995
Yes, my car originally had power drum brakes with single line master cylinder. I still have my original rear drum brakes and do not plan on changing them.
Glad to help if you have any more questions
Casey
Edited by wch on 06-14-18 08:28 PM. Reason for edit: No reason given.
Execution time: 0.205 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:28 AM
