Username Post: One wire alternator problem.        (Topic#351370)
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
05-31-18 10:36 AM - Post#2735502
Alternator is on my 36 Dodge street rod. Car has been in rebuild mode nine years, maybe 2 hours running time in past three years.
Wire from alternator post to starter post was pinched, bare spot on wire shorted and melted a portion of wire insolation. I'm not able to get a voltage reading from alternator post with no wire connected and engine running. The red rubber isolator on post appears ok but I haven't tried taking it off to check. Alternator has continuity from post to case. I'll be at Pomona Swap this weekend and will buy a new alternator but would like opinions on old one, hopefully it can be repaired.
Always appreciate your help. Thank you.
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
05-31-18 01:11 PM - Post#2735512
    In response to wings59
The shorted output wire probably blew a diode in the alternator. It can be repaired, but may cost as much as a new or rebuilt one. Take it to an auto electric shop. The diodes are inexpensive, the labor is high.
Edited by acardon on 05-31-18 01:16 PM. Reason for edit: No reason given.
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
05-31-18 10:35 PM - Post#2735548
    In response to acardon
Is it possible for it to put out 40 volts. When I checked two other alternator both were in 14 range. I couldn't get a volt reading but when changing meter setting I know I saw a 40. It was after that I checked continuity, post to case.
This alternator has been in the car for at least a dozen years, never a problem.
Thanks Don, I'll get a new one at Pomona and turn this one over to my BIL for repair.
I appreciate your help Don.
Larry
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
06-17-18 08:44 AM - Post#2737260
Just a follow up, new alternator is on and all is good. Thanks to all for your help.
Larry
Execution time: 0.153 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:59 PM
