Username Post: Dual Batteries for RV        (Topic#351297)
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
05-26-18 10:25 PM - Post#2735013
It's time to replace the battery in my RV. I would like to add a second battery to the system. I watched a couple U Tubes, one showing positive to one battery and negative to second battery. Second UT has pos. and neg. on same battery with jumpers to pos. and neg. on second battery. Are both of these correct hook ups.
Thanks for your help.
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
05-27-18 06:46 AM - Post#2735032
    In response to wings59
2- 6 volt golf cart batteries wired in series will give you 12 volts and the amp hours of 1 battery.
2- 12 volt deep cycle batteries wired in parallel will give you 12 volts and 2x the rated amp hours of 1 battery.
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2017 Silverado LTZ 6.2
2020 Blazer Premier
Edited by Dave in VA on 05-27-18 06:47 AM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-27-18 12:31 PM - Post#2735066
You have to be careful about what you see online. As Dave said, it depends on the battery voltage.
With 12V units, plan for parallel (plus to plus) all the time. The moment you try to series connect (plus to minus) you will fry everything in the RV.
Greg
'00 Explorer XLT 4.0 V6 Auto
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
05-27-18 12:46 PM - Post#2735071
    In response to CowboyTrukr
Batteries will be 12 volt deep cycle wired parrallel.
Thanks Dave and Greg, very much appreciated.
Larry
DECEASED
05-30-18 03:10 PM - Post#2735421
Have you considered using a switch or relay to disconnect the second battery when it isn't being charged? This way you can run the cabin electricals off the second battery without discharging the engine cranking battery. If the cabin battery runs down you can start the engine and charge it up again.
You might also want to look at this thread which mentions a battery isolator to be used for the same purpose.
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
05-31-18 11:03 AM - Post#2735500
Yes, I will be using a switch to shut batteries off when not needed. This is on a 2017 Jayco 5th wheel with one battery. It has an isolation switch for that battery but when off it also shuts off the power from plug in. I don't like battery not being able to isolate when plugged in but dealer say it is ok, will not hurt battery but it will not charge now and not even two years old. I store trailer at my house and it is always plugged in.
I will install isolater switch when I replace the batteries.
I'll have to put this on hold until next week, having a alternator problem on my old Dodge.
Always appreciate any and all help Ray, thank you.
Larry
Execution time: 0.155 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:48 PM
