Username Post: 1971 Camaro Z28 RS build        (Topic#351276)
Sauceman
Sauceman
Loc: Napanee, Ontario
Reg: 08-29-15
05-24-18 07:08 PM - Post#2734882
Hey Troops,
Just brought this one into the shop along with the 73 that is now waiting at the media blasters for some attention
Floors have been replaced at one time,
Just backing it into the shop!
First thing to do was strip what was left and put it up on the frame table to check for squareness.
The owner passed along his concern that the car was hit and repaired a long time ago, most likely in the late 70's early 80's. Well he was right, the car took a nasty hit on the right front corner and down the entire right side.
Here you can see the crinkle on the right cowl area in front of the A pillar.
This is a shot of the 73, notice how nice and smoe the outer cowl area is,
And this is the 71 and outboard of the heater fan hole is also pushed back,
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_09405 0_7412_zpshrhsyucf.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_09405 0_7412_zpshrhsyucf.jpeg[/IMG][/URL]
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_09410 1_4765_zpszr62ysy5.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_09410 1_4765_zpszr62ysy5.jpeg[/IMG][/URL]
The 73 is nice and flat,
So we took off the outer panel to hammer and dolly it back into shape,
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_09403 7_6332_zpsjb1ywega.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_09403 7_6332_zpsjb1ywega.jpeg[/IMG][/URL]
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_09442 7_8528_zpsxbet2nxs.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_09442 7_8528_zpsxbet2nxs.jpeg[/IMG][/URL]
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_09413 9_5782_zpsq7vkjxas.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_09413 9_5782_zpsq7vkjxas.jpeg[/IMG][/URL]
Now with that all sorted we repaired the firewall beside the fan hole,
And with that done the outer cowl piece goes back on,
We could also tell the whole A pillar was pushed in which pushed up on the roof. The brazed some anchors near the door hinge points to pull out the pillar,
[URL=http://s140.photobucket.com/user/SaucemanRC51/med ia/1971%20Camaro%20Z28%20 RS/Resized_20180524_10010 7_7717_zpsfde9sany.jpeg.html][IMG]http://i140.photobucket.com/albums/r13/SaucemanRC 51/1971%20Camaro%20Z28%20 RS/Resized_20180524_10010 7_7717_zpsfde9sany.jpeg[/IMG][/URL]
Here you can see the wrinkles on the roof,
And a full quarter was installed, but they really cheated,
They were too lazy to remove the rear window so they trimmed the metal around it, you can see the brazing line just under the window opening and the just layed the new skin over the old one inside the trunk seal cavity,
And we got the front fenders down to metal, luckily these were pretty good with just minor rust on the bottom of the drivers side,
Insides all GTG!
So when the A pillar gets finished tomorrow we'll start on the right side rocker
???????cheers
Good judgement comes from experience, and often experience comes from bad judgement.
Yugoslavia '94' , Israel/Syria '99 , Bosnia '02 , Afghanistan '08-'09
05-24-18 08:10 PM - Post#2734888
    In response to Sauceman
Thanks for sharing, I've subscribed to this thread and look forward to updates.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
05-28-18 07:42 AM - Post#2735135
Lookin' good so far!!!
Hey T @!
Joe
Sauceman
Sauceman
Reg: 08-29-15
05-30-18 06:23 PM - Post#2735433
    In response to wagonmaster
Did more metal removal today, right side 1/4, outer wheel well, and tail light panel.
This car was crashed big time and very hastily repaired, they used metal Lux bondo instead of welding lol, and where they did weld the really melted the parts together making simple spot weld removal a hassle.
New rocker tacked in,
Most of the 1/4 removed,
Parts of the tail light panel and trunk drop removed,
The fuel tank braces were fully welded, makes it a little harder to remove than just a few spot welds lol,
Good penetration though haha,
Getting it ready for re-assembly,
cheers
Sauceman
Sauceman
Reg: 08-29-15
06-08-18 06:17 PM - Post#2736355
Got some more work done test fitting panels,
Also got the door skins on,
Still some more rust to deal with in the trunk but nothing too major.
Also had to fix this 81, somebody keyed it right down to the metal.
We added a dulling agent to the clear to give it a weathered look to match to original lacquer.
All fixed!
???????cheers
Sauceman
Sauceman
Reg: 08-29-15
07-04-18 05:27 PM - Post#2738975
So before we welded on the 1/4's we made sure to remove any corrosion on the inner panels and cover them with epoxy and topcoat.
1/4 welded on,
Test fitting the tail light panel,
Installed the rear bumper checking for proper alignment,
And now it's off the frame table as all the structural welding is complete. Here we will touch up some previous floor repair and then take it to get sand blasted of the original panels that remain and we'll start the body work.
???????cheers
Edited by Sauceman on 07-04-18 05:28 PM. Reason for edit: No reason given.
NYH1
Loc: Central New Yorkistan
Reg: 07-15-09
07-04-18 07:21 PM - Post#2738992
Good job man!
NYH1.
'78 Camaro, mild Vortec head 385 stroker, 9.1 comp. Lunati Voodoo 262/268 hyd. ft. cam, RPM intake, 650 AVS carb, TH350 Coan 11" 2600 stall, 8.5" 10 bolt. 3:42 posi, 1 5/8" full length headers, 2 1/2" Flowmaster exhaust system.
Execution time: 0.163 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:15 PM
